Got a synchrowave 350 from a trade
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    May 2019
    ALGERIA
    67
    21
    22
    Default Got a synchrowave 350 from a trade
    I traded a old junk 6" atlas lathe for a synchrowave 350
    How did I do?
    I was surprised that it's single phase
  2. Likes Mud, moonlight machine liked this post
  3. #2
    Mar 2009
    5,376
    97
    1019
    You did good. That is if you like the heavy stuff. Now a rolling base needs to be fitted.
    The design uses bolts/nuts to secure torch connections inside the lower panel. The connections on the newer machines use DIN push and turn connectors. So what.
    Find out if you have any options on the front panel. "Spot Time", "Final Slope", etc. From the picture it looks like a few options are missing. Again, so what.
    Sep 2006
    Sacramento County, California
    3,874
    2440
    1362
    You did good! If it is anything like my Syncrowave 200, it will be bulletproof. Those old transformer machines, while not having all of the bells and whistles of the modern inverter units, will still pull a nice arc and do some great welding.
    Enjoy!
    Jul 2004
    Houston, TX USA
    30,463
    But they do get old and tired. My 250 - bought new in '91 - has had one component failure - just a selector switch
    Jun 2008
    Dassel,MN,USA
    135
    17
    55
    Picked up the exact same machine for $750 at an auction two years ago. I had a very old Lincoln ideal arc. sold it for $500.
    Thought I died and went to heaven, my welds got that much better.
    My son has one of the brand new miller inverter wleders. I tried it and didn't think it welded a bit better. Now it does weigh less than 1/4 of my blue box.
    its real easy - if its a blue box, its a good welder.
  7. Likes Newman109 liked this post
  8. #6
    Sep 2006
    3,874
    2440
    1362
    Quote Originally Posted by johnoder View Post
    That's typical for Miller. My friend has a Miller 200 MIG welder that's been used frequently at his machine shop for the more than 30 years he's owned it. Nothing needed but the usual consumables and one new Bernard gun. Most Lincolns are pretty much as reliable as well.
  9. #7
    Mar 2009
    5,376
    97
    1019
    Quote Originally Posted by Karl_T View Post
    The lighter weight inverters weigh less yes. Easier to walk away with too.
  10. #8
    Aug 2010
    Santa Cruz, CA USA
    172
    268
    64
    You did very good, can't be that old with the digital readouts. I have a 500s much older than yours and love it for welding the bigger stuff. Did it come with a torch and pedal?
  11. #9
    Feb 2019
    Iowa
    20
    I bought one of those a few years ago for $300 plus $385 shipping from HGR. It showed up to my shop and actually worked great! Very happy with the 350 and welded a lot of aluminum with it. Heavy machine but welds sweet! You did good on that one.
  12. #10
    Mar 2009
    5,376
    97
    1019
    I remember a person talking to me about his 350. He said he bought it primarily for the low end, 5 amps.
    He compared a 250 with a 350 and his opinion was that the 350 arc was a little more stable.
    My opinion is that a 250 is just as good as a 350.
  13. Likes ernieflash liked this post
  14. #11
    May 2019
    ALGERIA
    67
    21
    22
    Quote Originally Posted by gary-sc View Post
    Unfortunately no it didn't come with a torch and pedal.
    Anybody have any suggestions for torch and pedal? Should I just stick with the miller stuff?
  15. #12
    Apr 2004
    ANTIGUA AND BARBUDA
    1,290
    6756
    1007
  16. #13
    Sep 2006
    3,874
    2440
    1362
    Quote Originally Posted by converterking View Post
    This pedal would work nicely. For a gun, you could get either a Miller or a Bernard.
  17. #14
    Mar 2009
    5,376
    97
    1019
    Quote Originally Posted by West-7 View Post
    A water cooled torch requires a connection to a cooler. The guy I mentioned before made his own cooler. It was a box with a small water pump. I didn't care for it.
    Miller made a 350 LX model that had a cooler inside the main box. The water reservoir was a plastic bottle. There were some problems with the water pump keeping enough flow with a few units in hot places like Florida. The issues only occurred when welding stuff like 1" at the very high end. Miller sent out external replacement cookers. I don't if that eventually caused the LX to be discontinued.
    These days the cooler is external and sits underneath the main box.
    I would stick with a Miller foot pedal than something like this:
    TIG Welder Foot Pedal For TIG Welding Machines Power Control / Welding Equipment | eBay
    The torch I use is a WeldTec. With CK you can get a rotating head. Then you will need a 50' long sheath to cover your torch gas and water hoses.
    The Miller runner package allows you to have two gas bottles in the back.
  18. #15
    May 2019
    ALGERIA
    67
    21
    22
    So this machine has the writing and punch outs on the panel for pulse.
    Can I add this to the machine?
  19. #16
    Mar 2009
    5,376
    97
    1019
    That is an option that has to be purchased. Ask at the millerwelds forum.
  20. #17
    Apr 2004
    ANTIGUA AND BARBUDA
    1,290
    6756
    1007
    Don't forget that you live in a cold climate and will need antifreeze if you get a tig cooler. I have always used the Miller coolant which is quite expensive. I have heard of others using automotive antifreeze with different levels of success. If you have questions call Miller tech support, they have always been helpful.
  21. #18
    Sep 2006
    3,874
    2440
    1362
    Apparently,the use of automotive coolant in a TIG welder cooling unit is a sore spot with the manufacturers and welding machine owners. Internet wars have been fought over the use of various items that are unusual or less expensive than the "right stuff".
    I use distilled water with a cup of Lysol to keep the bugs out. It's fine where I am since it never gets below 40 deg. F. in my shop area. In the past I've used the Miller Coolant but it's way too expensive for my taste.
    I've also used Dex-Cool auto coolant about 25% with distilled water with no apparent harm.
  22. #19
    Apr 2004
    ANTIGUA AND BARBUDA
    1,290
    6756
    1007
    Quote Originally Posted by Newman109 View Post
    Thanks, that is good to know. I have heard people say it didn't weld as good with auto antifreeze so I just bought the Miller product. I will be changing it this fall. As far as foot pedals I never liked the factory Miller unit. It is taller and my knee would be sore after a short time. The SSC is like the factory Lincoln pedal which I prefer.
  23. #20
    Sep 2006
    3,874
    2440
    1362
    I've never noticed any difficulty with welding regardless of what I used. When I bought my first TIG welder a long time ago, it came with a home built cooler which I still have. The previous owner had been using soluble oil in the cooler which worked fine but permitted the formation of lumps of nasty stuff in the tank. Even though it welded OK, I got rid of it and went to distilled water and Lysol.
    With a machine as large as a 350, as mentioned above, you will want to make sure that you have a cooler on it. Also, you will need enough electricity to power it. I have 100 amps available for welding in my area but some machines would require more.
    Good luck!
