Hawaii Machinist
- Jun 10, 2006
- Hilo Hawaii
Well, after attempting to MIG weld something and realizing that there was a fine coating on my spool of copper coated .032 mig wire and that the rust would foul my liner and not let me weld, I gave it a rest. This morning I went to the local welding supplier and bought something that I earlier saw at school. It is called Weld Aid.It takes 2 parts. The first is a bag containing 6 foam sleeves and retainers and the second is a can of lube or solvent. I installed 2 sleeves onto the wire between the spool and the feeder after soaking them with the solvent/lube. The foam sleeves are slit half way through and just slip over the wire and there are steel retaining sleeves that fit over the foam to keep them in place. VOILA, like magic there was no problem doing my project In fact the lube reduced friction so much that the wire speed had to be reduced by 30%-40%
I just thought that I should share this with everyone. Here is a link to the products. No affiliation.
http://www.weldaid.com/lubematic.htm
