BILLY-I.A.M.BL11201
Cast Iron
- Sep 28, 2006
- Mass/Conn
In the course of our operation, we have a crusher and disintegrator station to break up our material- dried clay, which includes "clay dogs"
Presently we have a roller setup, J.C. Steele, that utilizes 12 insert disintegrator bars that are hardfaced. During the normal course of operation, we notice that the hardfacing breaks off the mild steel backer bar, which requires us to reweld these several times a month.
A call to Steele gave us info that the bars are tool steel, or not. They are indeed mild steel, and we have been filling the larger divots with 7018 prior to hardfacing the surface with Stulz
5/32 or 3/16 hardfacing rod. This rod tends to "pull", and develops heat cracks if aggressively welded.
Got a box of Cronatron 7770 and 750 to build up and face the bars, at the recommendation of a local supply outfit.
Any suggestions about specific techniques in welding this- there is less than 1/2" of the bar hanging out of the roller, and they are not easily removable. I was told preheating the bars to 250 to 300 degrees would make the welds take better, but this may be difficult to accomplish with so small an exposed surface.
I plan on using AC reverse welding, electrode positive, 180 amps on the 5/32 7770, and 180 amps on the 3/16" 750 to finish.
Any experience out there I can tap into?
Billy
Billy
