Heat treat question.
Likes Likes:  0
Results 1 to 6 of 6
    Jan 2006
    Cin. Ohio
    8
    Default Heat treat question.
    First want to say hi to all. New guy here. Not sure if this is the right place but I have a heat treat question. I'm in a small, small shop with limited resources. I have made a small piece out of 1045 steel, 25mm OD, tapers to 7mm and 25mm long, I use to press sleeves into another part. The metal sleeve is also 1045. It has a .5 step and after a while the little step on the pressing part wears and gets out of shape. I'd like to harden it to last longer. As I said I'm limited on what I have available but we do have a set of torches here and wondered if I can use them to heat it up to a glowing red and then dip it in water . Would that give me some hardness or make it brittle? Thanks.
    Dec 2008
    IL/WI border
    3,210
    1016
    937
    Yes, you can harden it with flame (bring it to the point where it stops being attracted by a magnet), but you need to do tempering to avoid excessive brittleness. Ideally, tempering is done at about 550-560F. Some household ovens can go almost that high, but if the part is not large, you may get by with using you torch to evenly re-heat the metal to dark blue color. Try to do tempering right after hardening to prevent cracks.
    Water quenching is fine, but brine would be better for more even cooling. Expect some deformation (brine will lessen it a bit).
    Jul 2004
    Houston, TX USA
    29,752
    but brine would be better for even cooling
    Which means salt water
    The salt reduces the generation of STEAM at the metal / quench interface
    STEAM is just an insulator, interfering with the quench process
    Jan 2006
    Cin. Ohio
    8
    Thanks. That's very helpful. And I take it I'd temper or re heat after quenching it?
    Jul 2004
    Houston, TX USA
    29,752
    Quote Originally Posted by PDETRO View Post
    To some temperature desired. Thumbnail is 4142 Mass Effect data which would be a little different from 1045. Note all examples on page 15 are quite high (1000-1200F) - meaning more TOUGHNESS and less hardness
    The chart on page 14 gives other examples of tempering temperatures, and the temperatures at bottom relate to the hardness numbers at the top - in both Rockwell C and Brinnel
    On Edit....The 1040 data say 42 Rockwell C at 700F, where the 4142 says 47 - as an example of the differences
    Mar 2005
    Kansas
    7,466
    429
    3425
    They make preheat treated steels which would be ideal for your situation. It can still be machined with normal tooling, but will provide a much longer life for your tool.
    Then you can read up on steels and heat treating and learn about that as a separate subject.
