Help!....... dangerous argon cylinder
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Oct 2020
    11
    Default Help!....... dangerous argon cylinder
    I sent my son to purchase a used 80cf argon cylinder i found on the offerup app and when he came home I saw all the information that is usually stamped onto a tank has been grinded off. I tried to exchange it but not surprisingly nobody will take it. My son learned to be more careful.
    The dishonest man that sold it to us won't respond anymore said it was half full during the bargaining of the price. I have his address but I'm going to try reaching out to him to see if he does the right thing. Its only $60 so to me its not worth it to risk trouble if I go to his house
    If I use some tie straps to secure it to a tree or pole can I slowly open the valve to drain any gas it might have? It makes me nervous that the grinded down areas are much thinner and can cause a rupture so by draining the tank ill be able to use it as a manly ornament or go dump it on the guys lawn.
    Would it be dangerous to vent argon? I'm lost on this right now guys
    Oct 2011
    CANADA
    British Columbia
    657
    70
    425
    Argon is totally inert so as long as you open valve outside in open air no one is going to be asphyxiated. I have seen guys take cylinders that are out of commission or failed test and cut the bottom off. They make great dinner gongs hanging from a rope.
    Mar 2014
    Nebraska
    402
    42
    241
    Roll it outside and crack the valve, it will bleed off eventually.
    Nov 2004
    Webster Groves, MO
    7,779
    2006
    3734
    Air is .93% argon. We get the argon for welding, etc., simply by separating it from air. As hobbyman says, It is completely harmless as long as you do not have such a high percentage that it displaces breathing oxygen.
    Bill
    May 2017
    Minnesota
    1,429
    1841
    949
    Then cut the top off, flip it over, and use the bottom for dishing sheet metal into:
    Oxygen Cylinder Dishing form. Ten second tip #17 - YouTube
  6. Likes lalojamesliz liked this post
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,310
    1651
    2623
    So your son learned a lesson........how about YOU? Next time go look at the item yourself.
    As far as venting it, lay it on the ground, inclined up in the front, and pointed in the general direction of the sellers location.
    Whack the valve with a big hammer, snap it off, and send the cylinder skyward, hopefully to it's intended destination. If something goes amiss, blame it on your son.
  8. Likes Garwood, JohnEvans, Demon73, Limy Sami, Rudd and 2 others liked this post
  9. #7
    Aug 2012
    California, Central Coast
    4,968
    2361
    2042
    Why vent it? Did you not want to buy an argon cyl? I would just use it and when empty deal with it then.
  10. #8
    Jul 2011
    Brusly, LA
    834
    21
    346
    Go to that guys house point the bottom at it, hit the valve with a hammer, tell him to mail you your $60 back
  11. Likes lalojamesliz, Mark Rand liked this post
  12. #9
    Oct 2009
    Olympia, Wa
    725
    325
    230
    lol I was just gonna say go huck that thing through his front window. Just joking. I had a similar experience and learned from it, but mine was $250. If the asshole wont respond I would just use up what gas is in the tank and take the loss. Maybe you can make something useful out of the tank once its bled.
  13. #10
    Oct 2020
    11
    Quote Originally Posted by dkmc View Post
    Ha ha ha that's how I feel about it too. I didn't tell him anything about the stamping so I guess it's really my fault. He was just the messenger.
    My son and I learned
  14. #11
    Oct 2020
    11
    Quote Originally Posted by Rob F. View Post
    Since it hasn't exploded already I guess its still safe.
    I went outside to get it from my backyard and I planned to now use it but I saw paint chipped off the sides with bad surface rust. Don't want to chance it now so I cracked the valve open and screwed the top back on and its venting in the corner of my fence. Oh well
    Thanks for all the suggestions guys.
  15. #12
    Oct 2020
    11
    Quote Originally Posted by mhajicek View Post
    I'll do this.....thank you for the idea
  16. #13
    Jan 2002
    West Coast, USA
    8,989
    591
    6428
    Cylinder markings are usually on the heavy collar, not the sides of the tank. If the collar is what was ground a bit, the cylinder is likely still safe - might have a bit of argon to be used??
    A lot of those old tanks are turned into bells / gongs. So, not only do you get a dishing die - but maybe a gong. Give it a whack now and then to keep the lesson fresh?
  17. #14
    Jan 2007
    wales.uk
    1,340
    198
    242
    Since some dick was dull enough to grind the test etc off, you sure you have argon, not CO2 or N2 ?
    If it’s got a yellow top it’s nasty stuff!
    Mark
  18. #15
    Oct 2013
    The Gorge, Oregon
    200
    41
    154
    Make a gong out of it. Drive by the guys house randomly at 3am and wack the cylinder with a BFH. Scream out:
    “You’re on the Gong Show!”
  19. Likes Blazemaster liked this post
  20. #16
    Oct 2004
    Iowa
    3,259
    86
    473
    I would have connected the tank to my welder, opened the valve, and allowed the argon to gently flow into my shop, over an electrified wire, until that Argon was totally converted to All-Gone...
    Then disassembled the tank into usable pieces for other purposes.
    Like cutting the body into 2" wide rings, welding flat plates to the edges, boring through it and welding in some tube machined for cartridge bearings, and calling them brutal-duty casters!
  21. #17
    Sep 2010
    Oklahoma City, OK
    5,288
    976
    2278
    Quote Originally Posted by PeteM View Post
    Right, it'd be pretty dumb to go to the trouble of drawing a seamless bottle only to stamp it full of stress risers at the end.
    Use it up, take it to your gas store and let them handle it. You won't be their first case of this.
    Sent via CNC 88HS
  22. Likes digger doug liked this post
  23. #18
    May 2006
    Seattle
    2,289
    55
    557
    Quote Originally Posted by lalojamesliz View Post
    That's a high pressure cylinder. It's spun from 3/8" steel. Don't worry about a little rust. Use up the gas and be done with it.
    I think about situations like yours as "I paid $5 for the cylinder and $55 for a valuable lesson in the school of hard knocks".
    metalmagpie
  24. #19
    Apr 2004
    Modesto, CA USA
    8,073
    1491
    My understanding is when they do a hydro test first they stamp the cylinder with marking to indicate it passed. Then they preform a test and if it passes all is good. They stamp first in case the stamping causes stress risers making it fail at extreme test pressures.
    I suppose if it fails they would have to destroy the approval stamp or the entire bottle before it leaves the test area. Maybe that is why they ground off the test stamps, because it failed? Failure is seldom spectacular. It is more likely it ballooned out too large indicating the walls are getting too thin.
    Bil lD
  25. #20
    May 2019
    Michigan
    2,412
    1250
    1770
    Quote Originally Posted by Bill D View Post
    <snip> Failure is seldom spectacular.............
    Only takes one time................
