I have a Smith's cutting/welding torch set that came from an estate sale some years ago that recently suffered a near catastrophic failure. I've used it a bunch as it has the small bottles and I can take it places to where it's needed. Since I've owned it, it has always sort of pulsed when I go to cut something although it would still do the job. The other day, I was using it to heat and bend some small parts and when I shut it down, I noticed the cutting tip was glowing prompting me to take the tip off and clean it. I also took the cutting torch apart and cleaned it which had lots of carbon inside. Put it all back together and tried it but found the flame once adjusted would get slowly get smaller as if I was adding more oxygen. While attempting to to adjust the mix to get the desired cutting flame it started to pulse again and I could see the line pressure gauge jumping around which I had not seen before (and had looked before). The hose was also pulsing so I shut it all down. Then I noticed the hose was warm and kept getting warm. I closed the valves on the bottles and eventually it all cooled down. Oddly, the oxygen hose was the one getting warm. Disconnecting the hose from the torch mixer and the O2 hose was filled with carbon as was the torch mixer. I bought new hoses and have ordered a rebuild kit for the cutting torch. Took the mixer apart and ran it through the sonicator. I can't seem to comprehend what was happening here. Anybody have ideas?
