snowman
- Jul 31, 2004
- Southeast Michigan
So that's what I've got set up. Literally a montgomery ward AC/DC buzzbox with output leading to an HF251D that I picked up dirt cheap. In the process I also have a Powertronics SCR that controls one leg of the welding transformer for my pedal.
It works pretty good, but my gas useage is not what I would consider acceptable. The solenoid on the HF251 is set up so that as soon as you turn the machine on, the gas flows. This gets a tad bit expensive.
I am thinking about adding a couple relays so that the gas only flows when the pedal is depressed. I will basically use the remote switch, or use one of the extra connectors on the 14 pin connector. Ultimately, I would like to have a post flow delay as well.
I'm just curious if there is any reason why I should continue to let this thing drain my tank, even when I'm not really actively welding and just have the machine on. (ie, what am I missing, this seems ignorant to me that it's wired this way)
