How do you calculate tonnage of a punch press
Results 1 to 5 of 5
    Dec 2004
    Northern Colorado
    182
    14
    Default How do you calculate tonnage of a punch press
    I picked up a small punch press. It is a Molex TM 40D. (Yes I suppose I could contact the manufacturer but I thought I'd test the knowledge here.) It was designed to crimp connectors onto wire.
    The specs:
    Fly wheel weight: ~35 lbs (Using online weight calc based on dimensions) 9" OD
    Fly wheel RPM: 365 (Laser RPM meter)
    Stroke: 1"
    Motor 1/3 HP
    RPM 1750
    Total machine weight: 210 lbs on a digital scale
    I was thinking of using it to punch aluminum gas checks for lead bullets. Online
    punch calculators call for .1 to .3 tons for the sizes I'd like to do. I have the equipment to make my own dies.
    Anyone have to formula to calculate the tonnage of this little press?
    MT6
    Sep 2010
    Oklahoma City, OK
    3,857
    673
    1677
    I've never done a flypress before, so I may be totally wrong, but here's what I get-
    Firs calculate energy of flywheel-
    E= 1/2(I)(w^2)
    Iz = 1/2m(r^2) = 1/2 * (35/32.17) *(.375^2) = .153
    w = 365rpm = 38.22rad/s
    E = .5 * .153 * 38.22^2 = ~112 lb-ft.
    Next calculate force-
    F= 112lb @1' = 2688lb @ 1/24' (if stroke is 1", the wrist pin's radius must be 1/2", or 1/24', right?)
    2688/2000 = ~1.34t
  3. Likes magneticanomaly, MT6 liked this post
    Dec 2004
    Northern Colorado
    182
    14
    Cole, thanks for the calculation. You might be close. I just searched on e-bay and found a two ton press that appears to have a fly wheel not that much bigger than mine.
    The attached pic is the e-bay Alva Allen B-2 2 Ton Mechanical Trip Bench top punch press.
    I have sent an inquiry to Molex's customer service but haven't heard anything from them. If it is in the one ton range it would do what I need, just have to come up with the time to design and do it.
    Sep 2010
    Oklahoma City, OK
    3,857
    673
    1677
    I didn't include the motor's tq, that'd add an additional ~4.8lb-ft.
    Jul 2004
    wilmington,mass.usa
    654
    14
    A quick way to determine press capacity is to square the diameter of the crankshaft main bearings and multiply by 3.5. This will give the capacity in tons.
