jermfab
Cast Iron
- Jul 25, 2013
- atlanta, ga
While most people don’t ever want to flip a car... and would surely never PLAN on doing so, for me it’s a regular enough occurrence. As with any other cat, there’s different ways to skin this one, here’s mine:
As I understand it, this “car flipper” concept is credited to John Frazier, Chuck Gaspar and Clay Pinney for a design they introduced filming “Armageddon”. All three men received a technical achievement award at the following years Academy Awards, Gaspar’s being posthumous.
Since then, some have gone bigger and bigger, my interpretations are the lightest and most compact I’m aware of. The inherent disadvantage of the design as a whole is slightly worse with my design, but I have the advantage of a smaller package overall and the actual filmmakers don’t have to work nearly as hard to hide my rigs. Some of the bigger units leave even vehicles with LOTS of ground clearance teetering comically off the ground. And subsequently force more work to hide their existence. The Acura TL on the lift in the background if the latest victim, it sits low, but the tires should still touch the ground while it’s on the units.
The unit has a high pressure side and a low pressure side. Here’s the low pressure actuation and the high pressure valve in its closed position:
Open position:
Here’s some stills from a test using 100 psi shop air on both sides:
Only the near unit is actually firing.
Despite inherent mechanical disadvantage of the original design which my design makes even worse, 1800 psi has pretty spectacular results, even with a heavier vehicle:
And from the other side:
Obviously there’s no truly SAFE way to fling a car through the air, but compressed gas is far safer and much more repeatable than the pyrotechnic solutions that were most commonly used prior to options like this.
In any case, I wanted to share some fun pictures of a project I’m proud of. I’ll update with pics of the Acura when it goes next Tuesday.
Be safe and stay healthy
Jeremy
Open position:
Jeremy
