How would one drive an old flat belt lathe
Likes Likes:  0
Results 1 to 6 of 6
    Feb 2021
    Default How would one drive an old flat belt lathe
    We have an old lathe that had a overhead drive system and were wanting to attach a gearbox and vfd 7.5 hp 3 ph motor. I had an old faye scott that was adapted that way. Any sugestions.
    Oct 2017
    1,242
    378
    424
    What RPM does it need?
    I'd personally just mount another flat belt pulley on a jackshaft to drive the lathe, and use a V belt to connect the motor to the jackshaft.
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,939
    84
    930
    why not connect it the old way , but use a vfd to control it. it sorta' worked then. if you have
    control of the ac frequency , with a Dodge or whatever 3 speed truck
    gearbox in control. and you can go to higher rpms, 700-800 is ok... they didn't have hss or carbide.
    nobody cared. so those 400 rpm top speeds were fine then. going from lineshaft belts to hangover ac-motors
    must have been a revolution. don't be afraid to go too fast . you will hear it howl if starts to detonate.
    good luck.
    Jul 2007
    Missoula Mt
    1,266
    55
    565
    The old flat belt drive cant take 800rpm more like 400 and it is pushing it, you need to post size of lathe and a pic or 2...Phil
    Feb 2019
    New York
    426
    399
    I don't remember much about it but when I was a kid Dad had an old flat belt lathe somehow hooked to a Harley Davidson transmission.
    Jul 2004
    Houston, TX USA
    31,954
    Quote Originally Posted by Phil in Montana View Post
    Amen - has to do with bearing material AND lube for same
    how to photos from a member - do note you have to work at making them slow
