I purchased a brand new hydraulic unit and control box for a materialift vertical reciprocating conveyer at an auction. I would like to use the unit as a hydraulic source for a 90 degree notcher. It has a hydraforce SV10-20M -4P - 24AP Normally closed 24V solenoid valve plumbed into it. It was used with a telescoping single action cylinder. I will be using a double action with a foot pedal to power the solenoid. Ideally I'd want a momentary pedal push down and the cylinder moves out. Take your foot off and it retracts. I probably will need a limit switch when the cylinder is retracted to direct flow back to tank. I believe I need a 4 way 3 position valve?
Right now I'm using a monster 15hp power pack
with a hand valve and have to plug in a long heavy cord when I use it. Am I on the right track?
