Workhaus
- Nov 9, 2017
- New Orleans
Hi all,
I'm fixing to build myself a new welding table and I'd appreciate suggestions about hole size/pattern, material thickness, etc. A little about my shop and set up:
I'm doing mainly custom architectural metal fabrication, primarily CNC plasma cutting components and welding them together. I'm not making too many jig yet, but I'm sure I will in the future. I have a 5x10 CNC bed and a forklift so I can move things around and be flexible. I do have somewhat of a small space and as much as I'd like a big ol' 5'x'10 sheet to weld on I need to be smart about my space. I have a bunch of welded aluminum table bases I acquired for free that are 3/16" square tubing and are super sturdy, so I'd like to get a top to go on that. The tops would then measure 36" x 54". For the most part this should be big enough, but I'm wondering if I should make pieces that could flip up to make it 48" x 72" or something like that. I don't have a clamp brand or style I'm married to yet, so I was figuring plasma cutting 1" holes every 6" or so. I was thinking 3/8" thick mild steel for the top with some sort of nut system underneath to lift the center as the table as necessary. Also, I'm curious how you prevent your table from rusting a bunch without having to put something applied on it to burn off as soon as it's welding on.
Let me know if there's something that you wish you'd done or have seen that would be helpful. Any input would be great!
