northeastconfederate
Cast Iron
- Jan 25, 2005
- New Egypt, NJ
I am welding two 12" squares of 1" thick steel plate together at their edges, and trying to keep them flat. Desired result is a 1' x 2' plate relatively flat. I am sure I started this all wrong: I beveled one side, hoping to keep a "finished" side without grinding. So far, this hasn't worked out very well:
I am using a Hobart Handler 175 with .030 steel wire. I made a couple of passes, not continuous, to try to limit the amount of heat at one time, and still ended up with a "V". I then flipped the piece over and grooved the "finished" side - the side I didn't want to weld or geind on - and ran a heavy bead on that side, which pulled the plate flat again. Then laboriously ground that weld flat. Now working on filling the "back" side again but I'm sure it's going to curl up again. So far, I've run a couple of short beads, letting the piece cool off significantly between welds, and already see movement.
How can I keep this flat? If I clamp it securely to the table until cool, will it just "spring" when I release the clamps? Am I going to have to keep welding on the opposite side to pull it back again?
This is will ultimately be a top for a mobile table (I have a total of four 12" square plates which will be welded into a single 24' square plate). It is also serving as a skill development exercise.
Any help?
Any help?
