Laser nesting software recommendations?
Results 1 to 18 of 18
    May 2019
    Michigan
    2,233
    1024
    1484
    Default Laser nesting software recommendations?
    I wasn't sure if this should be posted here or in the CAD/CAM forum....I guess I'll post it here and Don can move it if he sees fit.
    Like the title says, what do you use? Why do you like it (or not)?
    Doesn't need to be anything fancy, just bulletproof and reliable.
    Does anyone know if Cincinnati's software is compatible with other lasers?
    Thanks in advance.
    Nov 2014
    Florida
    5,475
    2182
    2702
    No idea if it's any "good", but Mastercam will do it.
  3. Likes empwoer, ChipSplitter liked this post
    Feb 2020
    Washington
    139
    14
    129
    We used bysoft7 on our bystronic laser while I was still doing that. Not sure if it's available standalone or if it just came with the laser, but it was the best nesting software I've used, and I've done a ton of nesting. Routers, waterjet, etc.
  5. Likes ChipSplitter, digger doug liked this post
  6. #4
    Oct 2005
    19,130
    Neighbor shop runs this:
    https://www.sigmanest.com/products/sigmanest/
    although a very old version of it, and not very much.
  7. #5
    Jun 2006
    Near Seattle
    5,063
    3595
    1479
    There is a freeware app called deepnest.io which can be fiddly, but I've had OK success with it for waterjet work.
    And at the price (and relative ease of starting) you can probably afford to try it out.
  8. #6
    Feb 2020
    Washington
    139
    14
    129
    I guess it's sort of important to know, are you just looking for something to nest .DXFs? Or are you looking for laser CAM software?
  9. #7
    May 2019
    Michigan
    2,233
    1024
    1484
    Quote Originally Posted by Camputer View Post
    It needs to nest DXFs and output as one large DXF (up to 3 layers). No code is generated, that's all done on the laser side.
    >>Mike, I thought you were kidding me about MC....
    Can you put multiple DXFs together and save as one?
  10. #8
    Apr 2019
    Arkansas
    1,574
    750
    618
    We use optinest.
    I can make a nest for you if you like.
    Sent from my Pixel 3 using Tapatalk
  11. #9
    Feb 2020
    Washington
    139
    14
    129
    Quote Originally Posted by ChipSplitter View Post
    Yes, you can. If you have mastercam that'll work fine for you. I used it on routers for years.
  12. #10
    Nov 2010
    Central Florida USA
    68
    36
    Many if not most lasers come with some sort of nesting software. Mine came with cypcut which is a sort of cad nest and laser machine operation software.. it gets the job done and was included. I do save my repeat job nests and I'll edit the nest to get a few more in because sometimes it gets stupid and will leave big open areas of wasted metal.
    I have found that instead of telling the software I need 1000 of each part on 20 sheets it's better to nest 50-55 of each part on one sheet. Do a little adjustment for best fit and then make up for any shortfalls on the last sheet. The main advantage is that when you strip 20+ sheets you develop a pattern that saves time. Having 20 slightly different nest results makes a mess.
  13. Likes bryan_machine liked this post
  14. #11
    Oct 2017
    646
    169
    183
    I've made all of my nests manually up until now, when we are getting a laser that I believe comes with cypcut.
    It's important for the parts I make that everything is all grained identically. (And we like to cut all parts of a set from the same batch of material, and certain parts need to be all cut from the same sheet). Is the part orientation pretty easy to lock in?
  15. #12
    Oct 2005
    19,130
    Quote Originally Posted by Strostkovy View Post
    I thought there is a "grain orientation" setting on these nesting programs
  16. Likes Strostkovy liked this post
  17. #13
    Jun 2006
    Near Seattle
    5,063
    3595
    1479
    And, given a sheet of metal, how do you determine the grain direction by inspection?
  18. #14
    Nov 2010
    Central Florida USA
    68
    36
    Yeah it's fairly easy, set your parts how you want them to be aligned either in your cad software or in the parts tab. Then use the "No rotation" option (sometimes it chinese text) and the parts will all be nested as you have them.. On the nest result you can select objects and shuffle them around.
    My basic nest video shows how cypcut nesting controls rotation at the 4:30 time mark.
    I touch on nest sheet editing a few times here. This video is how to split sheets into more manageable parts.
    I have another way that is slightly more complicated that will nest the parts into smaller sections, which works better with larger oddly shaped parts.
    Quote Originally Posted by bryan_machine View Post
    Normally sheet metal in 4'x8' or 5'x10' sheets will have come off 4' wide or 5' wide rolls. So the grain will normally run lengthwise. Normally metal curls slightly with the grain so holding the sheet from one end hanging you can see the bow and determine grain visually..
  19. Likes bryan_machine, digger doug liked this post
  20. #15
    Oct 2017
    646
    169
    183
    On aluminum you can see lines on the surface going along the rolling direction. On steel you can see and edge on either side is rounded, meaning those were the edges of the sheet at the roller. I've always seen the grain going along the long direction, except for material from one mill in Egypt that we rejected due to inclusions and delamination of the aluminum plate, and also severe cracking when bending.
    I really don't care what the direction is, I just care that it stays the same. Rotating them around randomly can cause in excess of +-1 degree of bend error, and that's the entire tolerance I am allowed, if I even get that much wiggle room to begin with.
  21. #16
    Apr 2018
    I tried this one, but it turned all my radii into multiple point segments. Waterjet operator wouldn't touch it. Base files were perfect.... still on the lookout for nesting software
  22. #17
    Jun 2006
    Near Seattle
    5,063
    3595
    1479
    Yeah, I had that happen with it too - so took the pattern it made and kind of manually copied it - or sometimes cleaned it up in solidworks. Neither is fun, both only make sense for cases where it found a nesting that would work when I couldn't - and it's free software....
  23. #18
    Oct 2014
    South Dakota
    86
    7
    Not familiar with lasers. We have hi def plasma and use sigma nest. Previous place I worked we used pronest which is now owned by Hypertherm. I much preferred the pronest software as it was much more user friendly for me. I would think they would have provision for lasers. Neither of these are by any means cheap tho.
