looking for weld nuts, but for rivets
Results 1 to 13 of 13
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    Default looking for weld nuts, but for rivets
    I have a customer wanting a very low profile mounting option (not showing on the front side, and very minimal on the rear) and we originally spec'd screws going into weld nuts but they visually stand out too much. I was cruising McMaster and I found pre-colored rivets and they would work perfectly but the rivets can't protrude through the front surface so I was wondering if there was such a thing as a weld-nut, but the opposite.
    In my mind, this is a piece of weldable rod with a counterbore on one side and then a 3/16" thruhole. Weld the C/B'd side to the item and then pass the rivet through the hole, pop it, and ta da. A tube nut would work in a pinch, but I need these 50-100 at a time so $1/ea is more than I'd like to pay.
    Obviously I could make these, but surely they're cheaper elsewhere should an item exist. And if they don't exist, I'm going to post an RFQ in the MFG forum.
    Nov 2013
    Eastern Massachusetts, USA
    4,876
    4838
    4848
    I'm sorry but your post is a little hard to understand.
    If my take is correct, you want the rivets heads flush with the surface. If that's the case why not just use ordinary weld nuts of a size that you could expand the rivet into the threads and mount the weld nuts behind an oversize hole in the sheet that would act as the counterbore. There are thin head rivets if needed. AFAIK there is no such thing as a counterbored "weld nut" with a non-threaded hole.
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    Quote Originally Posted by Scottl View Post
    Damn, because that's exactly what I want, ideally a 1/2" in height.
    One of the downsides to the weld nut idea is they are typically very thing wall and thus require a tight fitting hole. I'd like to have the holes 1/16" over nominal to ease manufacturing and that just become a through hole to a weld-nut.
    I'll play with expanding rivets into the weld nut threads tonight and see what happens.
    Apr 2002
    Syracuse, NY USA
    9,757
    19
    589
    Pen studs have flush heads. You can press them in with an h frame press.
  5. Likes digger doug, gary-sc liked this post
    Aug 2005
    North Cornwall, UK
    165
    78
    Flow drill then countersink.
    Flowdrill - Flowdrill
    May 2006
    Seattle
    1,964
    38
    377
    Airplane "skin" is riveted on. The aluminum is countersunk and a rivet of the appropriate taper is then used. The result is strong and flush and doesn't at all look welded.
    So I suggest tapered rivets.
    metalmagpie
    Sep 2010
    Vancouver Canada
    956
    713
    352
    Can you say how thick the sheet materials are that need to be connected? I'm not entirely getting the picture. Studs or aircraft rivets as discussed above are fine choices but for 20 to 16 Gauge you might consider the more exotic PEM Spotfast Rivets https://www.pemnet.com/fastening_pro...pdf/sfdata.pdf They do require you have access to both sides of the part at the same time but I've used them and they are pretty tidy.
  9. #8
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    I should have posted these pics initially, the back plane and lettering are 11ga sheet. They didn't like how the nuts caused a shadow so I was off to find better solutions.
    I needed-
    1) nothing visible from the front
    2) nothing noticeable from the rear
    3) a permanent fastener
    4) a standoff of ~1\2"
    I ended up machining some doo-dads (100 of them) to fit my means so that I can use a colored, large head rivet to cover all of my bases. The work is at powdercoat now, Ill post pics when it returns.
  10. #9
    Oct 2005
    16,528
    Nelson stud welder.
  11. #10
    May 2017
    FINLAND
    1,914
    523
    871
    Double-layer sign if this was nothing more complicated than that.
  12. Likes mjk liked this post
  13. #11
    Jun 2013
    Northern Il
    1,364
    711
    1257
    Or else a bonding agent/adhesive.
  14. #12
    May 2011
    New Jersey
    629
    13
    216
    What about sex bolts? That way you can just screw them all together with thin pan heads.
  15. #13
    Jan 2016
    New York
    243
    6
    65
    Check with PEM Fasteners and Ohio Weld nut on the Internet.
    Roger
