Results 1 to 3 of 3
Thread: machined springs from rod stock
10-21-2019, 10:47 AM #1
Does anyone know how these machined springs from the companies Helical and Taylor Devices are manufactured? I'm assuming a waterjet with a rotary axis.
Home - Machined Springs
Machined Springs - Taylor Devices
10-26-2019, 10:15 PM #2
I have never seen them in-the-flesh, but I assumed for coil spring, drilled lengthwise and then the helix milled with an endmill.
You do not ask, but I do not like the idea. Metals are not isotropic, they have a "grain", like wood, created when they are rolled or drawn. A spring made from wire has the grain all within the wire. Imagine a helix carved out of wood: the grain will be wrong, and it will be very weak.
The "grain' of good quality metals is not as pronounced as in wood, indeed there are steels made especially to be uniform, isotropic, and free of non-metallic inclusions (VAR steels, Lukens "Fineline", powdered steels), but these are expensive. The "machined spring" people claim fewer parts...I see one very special, very expensive part, with no opportunity to replace just the spring if i want it a little softer or harder or if it breaks before the associated guides or spacers, washers, and clevises do..
10-26-2019, 11:29 PM #3
The one I want to know about is the one in my Boyer-Schultz grinder. It has a large pretension, no gap and no holes or clearance at the ends of the cut. I question the desirability of using one because it has quite a lot of wind-up and I have to wonder if that can cause torsional resonance compared to the insert type.
