Made your own electric grill? After 3 imports ones I want to make one.
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Mar 2009
    6,347
    124
    1237
    Default Made your own electric grill? After 3 imports ones I want to make one.
    The Sanyo grills sage in the center and the connections corrode from too much current.
    They are designed to wear out shortly after the manufac. warranty expires.
    Has anyone milled out a pattern in solid material and strapped calrod or something to heat the plate?
    Or maybe use stainless bars with 1/4" spacing? Not sure just yet how I would heat the bar. The preliminary
    study shows that I start with 120Vac and connect that to something, which is connected to the stainless
    cooking grid.
    If you did this, what material?
    I have some used calrod heat elements. Can they be bent? They could be strapped to the underside of a nicely
    milled out grill. The Sanyo grill has what looks like a calrod element that snakes it's way around the grill
    bottom. I should not have thrown out grills 1 & 2, could have salvaged the calrods.
    Apr 2004
    Modesto, CA USA
    8,708
    1685
    I understand that calrods can be bent to shape, gentle factory type curves. But only one time and never after getting hot. How do you think they bend them at the factory.
    Bill D
    Apr 2018
    8,873
    4299
    Quote Originally Posted by rons View Post
    George Foreman, and I don't care if they only last two weeks, Big George deserves every penny I can send his way.
    Dec 2012
    Se Ma USA
    2,276
    183
    1254
    WTF is an electric grill good for? Calrods are good for starting charcoal grills if you have one of those. We use a chimney thingy with newspaper to start ours. Otherwise MAN was put on earth to cook outside with FIRE. With a beer in his hand. Sorry, electric grill sounds like a whole lot of bad food. Oh, don't forget to use Free Range Charcoal.
  5. Likes atex57 liked this post
    Jan 2019
    Tennessee
    765
    228
    229
    wattco sells cast iron plates with encased cal rod. also sandwiched cal rod. https://1lw1tk46gr9aum2ilzzghvk5-wpe..._256131245.pdf
    Oct 2009
    Olympia, Wa
    795
    344
    253
    I have a stainless electric frying pan made by farberware, its a fairly heavy duty thing from the 80s. The kind of thing you would see in a thrift store and think nothing of it. I have used it to cook just about everything, and heats up really fast. It just has a cal type rod under a stainless pan, with a dial that goes from 150 degrees to 450.
    The oven is electric, does that make food taste shitty? heat is heat...
    Sep 2006
    SW Wisconsin
    759
    241
    280
    Mcmaster.com has " tubular heat elements ".
  9. #8
    Mar 2009
    6,347
    124
    1237
    Quote Originally Posted by EmanuelGoldstein View Post
    Breaking news report: Georgie poo is just a Front Man.
  10. #9
    Mar 2009
    6,347
    124
    1237
    Quote Originally Posted by Scruffy887 View Post
    I stopped the charcoal stuff years ago/ To much trouble. A grill with a tray underneath is going to work but not allow those tasty bits
    of burnt wood to flavor your roasted carrots.
  11. #10
    Apr 2018
    8,873
    4299
    I know but I don't care. He gets a portion. Heavyweight champion of the world at age 45, plus this ...
    https://youtu.be/PhSqgGRag_g
    Insane
    He can have my fifty cents ....
  12. Likes rcoope liked this post
  13. #11
    Oct 2005
    22,351
    Have you checked with the fine folks over at "Presto" ?
    Looks like everything is imported now, but it wouldn't hurt to check.
  14. #12
    Mar 2009
    6,347
    124
    1237
    A grill that heats up and cools like a Metcal soldering iron. And it should have stainless rods for the grill. What grade?
    If I could get stainless rods with a R value that is high enough to heat the metal when AC is applied across an array of 3/8 diameter rods 24" long.
    No chance about the R value being high. What about a high RF generator that safely skin-effects the heck out of the metal grill.
    Stuff won't taste as good as charcoal grill but I'm after a grill for outdoor use with no smoke.
    The import grills are cast alum with a heating element. Then there is a coating on the Alum that probably gets burnt off.
    Cheap approach not muck better than the imports:
    Mill out slots in a Alum slab. Then routing out a path for a heating element on the underside of the slab.
  15. #13
    Oct 2005
    22,351
    How about ditching the slab altogether, and using the calrods as the grilling bars ?
    Or, following the presto hot dog cooker, having no heating elements, place stainlees bars maybe 1" apart, insulated from grill body, put 120 vac on the bars, have the shut off power when using tongs/spatula.
  16. #14
    Apr 2018
    8,873
    4299
    For faster cooking, you could run it on 440
  17. #15
    Oct 2005
    22,351
    3-phase.....
  18. #16
    Mar 2012
    Geilenkirchen, Germany
    2,914
    1626
    1532
    3-phase.....
    Only if you are lucky enough to have it of course.
  19. #17
    Oct 2005
    22,351
    Quote Originally Posted by steve-l View Post
    Kalifornia has it in homes in some area's, search out Billd's posting.
  20. #18
    Nov 2013
    Eastern Massachusetts, USA
    7,468
    6192
    6639
    When you say "grill" do you actually mean a grill or an electric griddle. There are several manufacturers of 220v griddles the size of a stovetop for commercial use.
    There are also heavy duty electric grills such as this counter top model, but as you can see from the price they aren't cheap.
    E2412 EmberGlo - Char-Broiler, Electric, counter model, 12" wide | JES
    I wouldn't that used models are available at much lower price as restaurants many times change their equipment as their needs change.
  21. #19
    Oct 2005
    22,351
    Quote Originally Posted by Scottl View Post
    OOOH....It'a available in 3-phase....
  22. #20
    May 2006
    Seattle
    2,578
    65
    679
    I prefer a vintage General Electric Grill/Wafflebaker. Lest you think I don't know how to spell, see:
    Mine isn't quite as fast as the George Foreman it replaced. But it works flawlessly and it makes waffles!
    Plus, its shell is chrome plated steel. Find that nowadays! And, they go for peanuts on ebay.
    metalmagpie
