Manley Hydraulic press parts
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    May 2007
    SE Pa.
    75
    Default Manley Hydraulic press parts
    Looking for a rebuild kit for a Manley 20/40/60 ton hydraulic press. Can anyone send me a parts breakdown and supplier for these. Thanks in advance, Bill
    Oct 2008
    Maryland
    7
    Default Any luck?
    Did you ever find a place for parts?
    I have the press below and the screw down ram is stuck inside the adjustment wheel. The threads let go inside the wheel. Anyone know where I might be able to find another one? Or suggestions on how I might get it fixed or repaired?
    May 2003
    4,682
    369
    This is whats in them on the ram and the pump, with rope packing for the outer ends.
    http://www.epm.com/cup_packing.htm
    May 2008
    elmirage ca
    501
    30
    Default press wheel
    A steped sleeve would be a fix and thread to fit the screw,but it doesn't look like the is enough material to do that.So get a slug ,steel will hold up better Check the threads on the screw to make sure they are ok,then machine a new hand wheel per sample and to fit the screw . Not to tight as the threads will swell with use.
    Oct 2008
    Maryland
    7
    Thanks guys for the input..
    Drylake, what do you mean by steel slug? You mean just get solid steel rod turned with the correct thread pattern? Sorry if this is a stupid question...just kinda new to the whole fabrication thing..but learning fast.
    Oh, any machinists in the college park, Md area?
    Here are some additional pics:
    The wheel:
    The stripped threads in the wheel:
    and just for fun, here are some of my threads :-) :
    May 2003
    4,682
    369
    I fixed mine up around 25yrs ago. The threads were worn but have held up. At the time it looked like making a flanged internal threaded sleeve and boring out the hand wheel for it would not be a problem, there is alot of meat in that hand wheel.
    Mar 2007
    Lake Forest Park, WA
    341
    I have a 60 Ton version of that press that has been sitting ever since I bought it waiting to have the seals replaced.
    Oct 2008
    Maryland
    7
    Quote Originally Posted by Peter Miles View Post
    You must be telling me this because you want to sell me the ring and ram out of it right?
    Mar 2007
    341
    Yup, right after I sell you Galloping Gertie, the original Tacoma Narrows bridge!
    Oct 2008
    Maryland
    7
    Default update
    Machinist is going to take out the whole center section and just make a whole new one and weld the spokes back to new center section...I know the part is cast...so hopefully it all be good...the wheel and spokes only turn the ram...so strength there shouldnt be an issue. I should have it back late next week. Ill post up some pics.
    By the way, I did find a place that sells rebuild kits for the manley pumps...ill post that up when I find the link again.
  11. #11
    Oct 2008
    Maryland
    7
    Default donie
    Donie, did you have to order one of the piston cups from EMP? I ordered a repair kit from a company called blackhawkparts.com that was supposed to be made for my model press. Manley model 190. But the piston cup that came in the kit is to big. I was wondering if you ordered one, what size did you get. Looks to me the original piston cup is 5" diameter, 3/4" tall lip, 3/16" thick with 1/2 inch hole. The diameter is the part that is a little tricky...If I measure across the top it from lip to lip, it looks more like 4 7/8's measuring the across the bottom shows 5". I think the top measurement may be off just because the piston cup is a bit deformed.
    Anyways, all that to ask if you remember what you ordered?
  12. #12
    May 2003
    4,682
    369
    I purchased the cup seals from a supplier in Spokane Wa. that sold belting and other things. They are long gone.
    I believe my press is smaller with a 3 7/8" ram.
    If I were to do it again, I would probably try to fit a polypack seal to the ram by making a short piston to fit the top of ram or groove the ram itself ,if its thick enough.
    The seal I purchased back then was plain leather with no surface treatment, the same as what was in it.
    The problem with the old style seals like that is, oil sweats out enough so that the hand wheel is always a little oily.
  13. #13
    Apr 2009
    New York, USA
    I have a Manley press identical to the one pictured above. The problem with mine is that the pinion gear for the arbor press has some missing teeth. If anyone knows where I might be able to find a gear, and the rack if possible, please let me know. (Like if one of you guys gives up on fixing your hydraulic press and decides to buy a nice new one or anything like that).
    Or, does anyone know of someone who could repair my parts?
  14. #14
    May 2006
    Ft Worth, Tx
    90
    5
    Halltrail-Did you ever find the link to the company that makes rebuild parts for the Manley? I also need the seals for mine.
    Lewis
  15. #15
    Sep 2008
    Coggon Iowa usa
    169
    32
    I have the 40 ton version one of these. Mine leaks too. Good press otherwise.
  16. #16
    Oct 2008
    Maryland
    7
    Default as it turns out
    So I sent the kit back to blackhawkparts.com and it turns out that it is the right size cup...I just didnt know what I was doing. Supposedly, I need to work the cup a little to soften it up to get it in there...oops. I destroyed the cup that they sent me. But they are getting me a new one and sending it all back out. No charge. Pretty cool company. I talked to a couple of the guys that work there and they were all very friendly and helpful. By the way the sell kits for all kinds of presses. Check them out.
    www.blackhawkparts.com
    The kit for the manley model 190 comes with the piston cup, 3 sets of rope packing, two check valve balls and two other little parts...guess ill figure out where they go once I take the pump apart.
    Ill be ordering a kit for my Dake 6-225 soon too. I have a small leak in the ram. I suspect its the same type of issue...piston cup.
  17. #17
    Sep 2009
    Los Angeles, CA
    Default hi
    i am kenton i live in califronia i do have 60 ton press like that am trying to sell because it's to big for my used ,mine is in good working condition i realy need a smaller one if you know some one that is intrested let me know here is my email i can send you some pic of it thanks ken i will post it on the site today thanks again
    Attached Thumbnails Attached Thumbnails 006.jpg   008.jpg   007.jpg   001.jpg   002.jpg
  18. #18
    Jul 2001
    North Carolina
    1,981
    180
    408
    I have always liked the KR Wilson presses. They are hydraulic and also can be used like an arbor press. The handles of the handwheel are barely viable on the right-most side of the press. The pipe handle is for hydraulic pumping. Good luck fixing your press.
    --Doozer
  19. #19
    Jul 2009
    PA
    339
    16
    I just bought a 40 ton press like the one picured at the top of this thread. I checked out the link to blackhawk and didn't see Manley listed so I did a search with no results. I'd also like to ask about the threadind of the cables for the winch mine has no winch annd the bed has been disasembled and is bolted to the frame there are no spacers wich would allow the bed to move up or down.The picture shows me what Ineed to do to fix this problem but I'm not sure how to route the cables. Also I am missing the rod that is shown going up in front of the center of the cylinder and I'm not sure what its for. Thansks for any help Oscer
  20. #20
    Apr 2012
    Arkansas
    Quote Originally Posted by halltrail View Post
    I have a Manley press exactly as the one pictured, I'm looking to put a air over hydraulic pump on it and was wondering what psi rating was on the factory pump?
