Bill Simmons
Cast Iron
- Mar 5, 2006
- Auburn CA
I have two Lincoln R3S welders each with LN7 feeders. One of the welders is a 250 amp and the other is a 350 amp machine. I have one gun, a Tweco number 4. I plan to put this on the larger of the two welders and then get a 250 amp gun for the smaller one. These machines may be old dinasours but they were cheap. The only down side I see is that they take up significant floor space.
When I look at a Tweco catalog I find about 5 different models with no clear explanation of why one would select one over the other. I see a series for spray arc using mixed gases. Does one really need a different gun for CO2 vrs C25 or other mixes? Is there anything really differnt about these guns or is it just marketing? Do you have any recommendations or advice in making a selection.
I also see the guns are rated at either 60 or 80% duty cycle. This adequate for my purposes but seems kind of strange to put 60% guns on 100% machines.
The next question is connector style. Obviously the Miller ends don't fit the Lincoln feeders but what do the Tweco connectors fit? The catalogs say an adapter may be required but I can not find said adapters in the catalogs. Do they exist? The reason I ask is that I am cheap and will try to find a used gun at a low price but want to make sure that I end up with something I can use.
My next and last question should probably be in another thread but since I am on a roll here goes.
Most my use of wirefeed welding has been with inner shield so I have question regarding using gas. What is recommended in the way of purging air from the gun or is it even requried and if so how often if use is intermittent?
Bill
Bill
