02-22-2021, 12:16 PM #1
Miller plasma fault light problem
i have a spectrum 625 plasma machine that is giving a Temp fault light . when i turn the machine on
from cold @ around 55 deg - the air and cup lights go out , but the temp light stays lit and the thing won't
start . if i leave it idling long enough , the light will go out and i can get it to spray for about 2 seconds before it quits and the temp faults again.
i haven't used the machine in about a year - are there relays, contactors or sensors i should inspect
when i pull the covers ? i have the miller schematic, but it is more of ageneral wiring diagram and
of little help to me.
02-22-2021, 12:35 PM #2
It probably has a mechanical thermal switch somewhere in there that could use replacing. Think of where it would get hot and look for a little thing with two wires. Could be a metal can, could be a little tube, could be bolted to a transformer or heatsink or in the airflow.
02-23-2021, 08:48 AM #3
if its like a hypertherm, they do that when the contact tip gets worn out and it will prevent it from starting. it protects the cable that way.
02-23-2021, 09:16 AM #4
new cup, cone, swirl and tip. cable tests good for continuity.
02-24-2021, 11:41 AM #5
ya could be anything electrical internally. failures happen easier when colder. need someone good with electronics to test all the circuits related to it.
03-25-2021, 06:19 PM #6
it works fine now..... repair procedure #2 ........ i just left it on for 5 days straight..
. now it powers up and cuts like a champ. must have been damp in there.
03-25-2021, 06:21 PM #7
03-25-2021, 06:36 PM #8
many times... but removing the panels, it was spotless in there. no grit, dust mites or cobwebs.
digger doug liked this post
