Miller syncrowave 250 PCB burnt
Results 1 to 15 of 15
    Dec 2014
    North Carolina
    11
    5
    Default Miller syncrowave 250 PCB burnt
    I just bought this Miller syncrowave 250 for $500 broken.
    Serial LF430266L
    Power on, front panel lights up, all buttons work.
    HLP-11 fault code in one of the main switch settings DC-
    Welder won't weld.
    I disassemble the welder to find the back of the circuit card burnt.
    I need a good high resolution picture of the traces on the back of the board 209877D so I can repair.
    Sep 2006
    Sacramento County, California
    4,192
    2661
    1570
    Quote Originally Posted by BpWhight View Post
    I just bought this Miller syncrowave 250 for $500 broken. I can't find a serial number tag or sticker anywhere on it.
    HLP-11 fault code in one of the main switch settings.
    Welder won't weld.
    You probably already know that there are places that repair them amd Miller has new ones with changed part number. I wouldn't even attempt it.
    Miller-209877D | EIC Repair
    https://www.millerserviceparts.com/e...ssycontrol-int
    Nov 2017
    Virginia
    22
    26
    Can you give us a little more clarifying information. Are you interested in trying to repair the card yourself and save money rather than pay Miller $955 for a new card? I see your profile, do you have electronics experience/training? I don't own that machine to give you a picture of a card. I do know of a company in North Carolina who repairs cards. Will they repair this card and would the repair be cheaper than a new one from Miller? I don't know, I don't really know a lot about them but you can try contacting them.
    - Donna Green
    - Customer Service Representative
    - Quality Industrial Electronics-QIE
    - 8642 W. Market St. Ste. 118
    - Greensboro, N.C. 27409
    - 800-265-1999
    I really can't vouch for them as I have never used them, I was going to have them repair a Hobart card, they said they had repaired my Hobart card before and were hoping to repair it for less than $200. Till I got the card sent to them I discovered my problem was not the card so I never have used them. You can try reaching out to them. Maybe someone else on the forum can say yes they had good success with them repairing a card or no, they do not recommend them.
    Steven
    Dec 2014
    North Carolina
    11
    5
    Yes, it is over a grand for the upgraded PCB so I'm not going that route.
    I could send it to be repaired, As I've read there is a chance that repair will fail.
    But I'm the type of person who fixes everything himself, and I mean everything.
    I've fixed broken PCB's in the past, I know how to do so without causing further damage.
    The ARCing on the circuit board was between the 115v CB and the fan relay coil. I'm thinking water intrusion between PCB layers, or maybe an Ant, hopefully it wasn't HF
    Sep 2006
    4,192
    2661
    1570
    The main issue with repairing a welder with a bad PCB is that you cannot be certain that the damage could either be: 1. Within the damaged board only, or 2. As the result of a failure ahead of the board and which cascaded to damage the board.
    Without knowing for sure whether he problem is No.1 or No. 2, plugging in a new or repaired board is only done at great risk.
    Am I an expert at electronics? No, but I did spend 10 years working at the Litton Co. as a technical writer and I used to see waste baskets full of burned out boards. They would seldom repair one since they had lots of spares and fixing them was generally not cost effective.
    Good luck on this.
    EDIT: For the record, I own a 2006 model Miller Syncrowave 200. It was used but had only 20 hours on it when I bought it in that year. I used it quite heavily for a few years, but It's used very little anymore and still works well.
    If it were to blow a PCB board similar in cost to the OP's I would scrap the machine without any regrets. For $1k or so repair costs, I could get any number of late model inverter machines with more features.
    I'm just sayin'.
    Dec 2014
    North Carolina
    11
    5
    Well after cleaning the board inside the bubbled up portion, I can now see the missing burnt trace.
    My plan is to jump the traces with solid insulated copper wire.
    Reflow all solder connections in the immediate area.
    Check the main switch contacts with a multimeter at the PCB connection.
    Check the main transformer with a megger.
    Check voltages.
    Clean water tank.
    Reassemble and test. Hopefully by next week it's working. We will see
    Dec 2014
    North Carolina
    11
    5
    Quote Originally Posted by Newman109 View Post
    Good luck on this.
    I'm just sayin'.
    If I repair the PCB myself and it blows again, I've lost nothing.
  8. Likes vanguard machine liked this post
  9. #8
    Dec 2014
    North Carolina
    11
    5
    Quote Originally Posted by Welder want 2 be View Post
    - Donna Green
    - 800-265-1999
    Steven
    Yes I will attempt to repair myself.
  10. #9
    Apr 2007
    West Virginia
    1,209
    758
    532
    I recently bought a miller pipe pro 304. It had a bad board. I bought a technical manual for it on ebay. I have quite a bit of electronics design/Troubleshooting experience. I got it fixed. Parts cost me about $15.
    If you are accustomed to working on such things it’s worth a try. These manuals have theory of operation/troubleshooting and board level schematics. Make sure to get the one for the serial number range of your machine.
  11. #10
    Dec 2014
    North Carolina
    11
    5
    Quote Originally Posted by Pete Deal View Post
    I downloaded the manual which I was surprised to see a schematic down to the component level. Found an alternistor bad, so I'll just replace all 4 of them.
    My problem is that I'm used to Aircraft schematics, so much simpler to read!
  12. Likes Welder want 2 be, Pathogen liked this post
  13. #11
    Nov 2020
    Mississippi
    any luck with replacing the alternistor?
    I have the same exact symptoms and would like to attempt a repair myself. I see a burn spot on one leg of a resistor at the bottom of my card. I'd guess something shorted and burnt up.
    how did you determine that your alternistor was bad? Where on the board is it located?
  14. #12
    Dec 2014
    North Carolina
    11
    5
    Checked with regular multimeter set for resistance. Found the two large legs shorted to each other. But later found out it only controls the main fans.
    I found a bad resistor, waiting for it to come in, we'll see if that fixes it.
    I also ordered a digital microscope for 75 bucks so I can now see the small components easily. I'll keep working on this till I fix it....or I die, whichever comes first....lol. I figure at the cost of a replacement board, I can buy all the test equipment I need to fix it, and then be set for any future failures.
  15. #13
    Dec 2014
    North Carolina
    11
    5
    It's FIXED, those two little resistors nearest the board connections fixed it.
    Now to fix the remote won't control the amperage.
    I've already verified when turning the wheel on the remote that the resistance changes at the PCB connection. Which means their is still something wrong with the circuit board. But at least I don't get error codes anymore when switching settings.
    And I have to figure out why the water pump is not comming on.
    Eventually I'll have it fully functional.
  16. Likes Pathogen, Pete Deal liked this post
  17. #14
    Dec 2014
    North Carolina
    11
    5
    The remote does vary the 10VDC from 0v to 10v at the board connection.
    So after tracing the signal through the board for the remote, finding all the simple components good, I think the LM324M SMD IC Quad Op Amp chip is bad. Or rather if that chip dosen't fix it, then the main chip ATMEGA16 is bad. Let's hope that's not the case as I'd have to teach myself programming to replace it.
  18. #15
    Dec 2014
    North Carolina
    11
    5
    In full disclosure, the amperage adjustment was working when I bought the welder, it was probably me not following proper static electrical procedures which caused this issue.
    So, if you attempt something like this, then use a rubber mat, use a wrist ground strap, or rubber gloves, make sure work bench and all tools are properly grounded, and discharge your capicators......all of which I did not do. Static electricity kills PCBs.
