nopoint
- Dec 7, 2009
- Wisconsin USA
I have a Miller XMT 300 welder that stopped working. It should probably be replaced with a new machine, but doesn't get a whole lot of use. So I pulled the top cover off to see if there was any visual problems. Such as bulged capacitors, etc. I did find a burnt up component which would be easy to replace if I had any idea what it is. Component has integrated leads and was glued to the case.
Included my grubby finger pointing at component location as well as in reference to size of part. The component is a bluish color and contains no markings as it is burnt in half.
Any ideas?
Any ideas?
