Rick Rowlands
Titanium
- Jan 8, 2005
- Youngstown, Ohio
Down at the Steubenville Works of Wheeling Pittsburgh Steel I found an old motor generator welder today. I wired it up and turned it on and the AC side works fine. Comes right up to speed no problem. However I do not get anything from the DC side. It reads only a couple of volts at most, and the exciter at the brushes is reading only 1 to 2 volts.
What might be the problem with the welder? What should I be checking? I assume that the problem may be in the exciter, not putting out any voltage to the DC generator. What provides the excitation for the exciter?
I don't know who made this welder. The tag is aluminum and so heavily corroded that I cannot make out the name. Its at least 50 years old by my guess.
