water jetting pressures for paint removal
Results 1 to 7 of 7
    Aug 2011
    new plymouth id
    426
    27
    100
    Default water jetting pressures for paint removal
    Im looking at getting a high-pressure water system for paint removal on drilling equipment I have 5 trailer loads of equipment that needs painted, sandblasting is not an option because of the sand getting were its not supposed to. water can be drained out but sand is imbedded, I was looking into a pump in the 20,000 psi range and did not know if anyone here has experience in this type of system and if that is enough psi to cut good paints. I can find factory systems but they dont give a lot of details on psi for certain type coatings. Water Jetting pumps and equipment I can pick a pump up for fairly reasonable price then put together a system but would like feed back from those who have ran this kind of equipment.
    Mar 2012
    Geilenkirchen, Germany
    2,532
    1484
    1258
    I'm not an expert in this area, but I have found that pressures around 250 bar very happily removes paint unintentionally. I also must point out that at that pressure, it becomes difficult to control the nozzle. In that light, I would expect 500 bar would reliably remove paint, but hose and fittings required to perform at that pressure are very stiff and expensive. I would also expect that a nozzle/wand would be very difficult to control manually to the point of being unsafe to use. Just saying.
    Apr 2015
    AUSTRALIA
    712
    37
    157
    Your still going to have paint flakes going everywhere but i suppose its better than sand.
    Have you looked into dry ice blasting?
  4. Likes rcoope, Chip Chester liked this post
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,381
    1416
    769
    No experience with 20k psi, fair amount of experience with 3500 psi steam cleaner (same as 250 bar mentioned above), and agree that with a tight nozzle, the paint peels right off, sometimes unintentionally. Not sure what you need to strip, but water getting into bearings is an issue.
    Jan 2011
    1,381
    1416
    769
    Quote Originally Posted by Street View Post
    Have you looked into dry ice blasting? I have, the rates for equipment rental were not cheap, plus I need a reefer to store bulk delivery of dry ice, neither of which was cheap. It very well may be the answer to my paint stripping problems, but at current pricing levels, I will never know.
    Mar 2012
    2,532
    1484
    1258
    Quote Originally Posted by dalmatiangirl61 View Post
    Dry ice blasting is NOT recommended for paint removal. It is slow, unreliable and very expensive. Do your own research if you doubt my advice. No matter what you use for media, you will be subject to debris contamination. In every case thorough disassembly and cleaning will still be required.
    Aug 2011
    new plymouth id
    426
    27
    100
    I have a 3000 psi hot water washer that doesnt even phase this paint that is what we wash everything between jobs with but i havent tried it with a straight nozzle will start there. So the consensus is that 10000 psi should cut most auto style paints? I know there will be paint flakes everywere but that is better than sand i can get a used 10000 psi system for less than a decent hot water system. 20000 psi jumps the price a lot The wands are shoulder held and safty protection has to be worn of course that would cut your boot in milliseconds
