mjk
Titanium
- Oct 20, 2005
- Wilmington DE USA
Posting this to give someone the idea in case they are in the same situation.
I have Precision tig 225, Tombstone stick and a SP200 mig machine that all use 230 50 amp.
Keep in mind, only 1 machine is used at a time and welding is not my primary business.
Problem is I only have 1 outlet.
Not a real big deal, but each time I have to use the other machine I have to unplug and plug in the one I'm going to use and the wall outlet is behind the machines.
The solution was to build a way to have all 3 plugged in to eliminate the unplugging and plugging machines in.
Probably could have run 2 more circuits.......but that would be about $400.00
pics of what I came up with I have less than $100.00 invested.
The boxes and cart were salvage pieces, paint sort of matches the Lincoln red.
All 3 machines will stay plugged in.
The plugs are staggered to allow hand room around a each plug
The on off switch will be in the off position when welders are not in use.
