Multiple welding machine junction box
Results 1 to 9 of 9
    Oct 2005
    Wilmington DE USA
    1,970
    301
    406
    Default Multiple welding machine junction box
    Posting this to give someone the idea in case they are in the same situation.
    I have Precision tig 225, Tombstone stick and a SP200 mig machine that all use 230 50 amp.
    Keep in mind, only 1 machine is used at a time and welding is not my primary business.
    Problem is I only have 1 outlet.
    Not a real big deal, but each time I have to use the other machine I have to unplug and plug in the one I'm going to use and the wall outlet is behind the machines.
    The solution was to build a way to have all 3 plugged in to eliminate the unplugging and plugging machines in.
    Probably could have run 2 more circuits.......but that would be about $400.00
    pics of what I came up with I have less than $100.00 invested.
    The boxes and cart were salvage pieces, paint sort of matches the Lincoln red.
    All 3 machines will stay plugged in.
    The plugs are staggered to allow hand room around a each plug
    The on off switch will be in the off position when welders are not in use.
    Oct 2005
    13,796
    I did similar, but I welded the boxes together, and no switches.
    Jan 2008
    Valdez, Alaska
    194
    44
    85
    I think for that amount of effort you could have run a piece of conduit and eight wires.
    For a three way extension cord it's a humdinger.
    Oct 2005
    Wilmington DE USA
    1,970
    301
    406
    Running conduit would have required unloading pallet racks and multiple compound bends of the conduit.
    If I was in a situation where 2 machines needed to run at once, that would have been a necessity.
    Sep 2010
    Vancouver Canada
    862
    618
    296
    We had a switch between a wired-in spot welder and an outlet shared by the MIG and TIG welder and plasma cutter. Then we reorganized the welding area, removed the switch and put a plug on the spot welder so they all share one outlet. This is in a hospital shop and there is only room for one person to work on that bench but things must be to code, so no wiring all those loads to one circuit on the theory they'll never be used together. It's actually good to have these safety driven things as you can point to them when there's a safety committee visit and they are at risk of coming up silly policies in the absence of anything else to talk about. i.e. LOOK AT THIS ELECTRICAL LAYOUT. SAFETY IS ALREADY OCCURRING AS WE SPEAK!!
    Oct 2017
    513
    123
    133
    I sort of want to make a power strip similar to the ones you see for household use but scale it up to 240V 50A.
    Sep 2010
    Oklahoma City, OK
    3,971
    689
    1696
    If you can only run one at once, why are you concerned? Just hang 3 plugs off the circuit and call it good.
    Sent from my SM-T560NU using Tapatalk
  8. Likes digger doug liked this post
  9. #8
    Dec 2012
    Se Ma USA
    1,422
    109
    802
    I put 4)480 volt outlets on the same circuit. But only have 2)480 volt welders and I am the only one welding. Once in a while I have both welders on at the same time. But I have little expectations of mastering TIG and MIG welding at the same time, even though I have 2 hands. Maybe use the MIG to Hot Wire feed the TIG for some serious metal output?
  10. #9
    Sep 2010
    Oklahoma City, OK
    3,971
    689
    1696
    FWIW, per the electrical design engineers at work the NEC does not place a limit on the number of end devices that may be placed on a circuit (at least in the context of this conversation).
    Sent from my SM-G930R4 using Tapatalk
  11. Likes Strostkovy, digger doug liked this post
