Bondo
Hot Rolled
- May 14, 2011
- Bridgeton NJ
I need to build 3 different sizes of label rewinder for a customer of mine, and the whole system is pretty simple. But I am drawing a blank when coming up with a slip clutch, bearing, design so the shaft spins but the labels dont spin. If you dont know what a rewinder is, this is needed so when the label printer stops, it doesnt burn the motor up, or knock it down itself.
I will need to build one like the size in the picture 8" diameter, and up to full size rolls at 12" diameter.
