Need a shear for cutting 3" aluminum bar
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Dec 2003
    Washington
    4,633
    2134
    3922
    Default Need a shear for cutting 3" aluminum bar
    I am working on a flying shear to add to a continuous casting line that we did a few years ago. I need to cut through a 3" square aluminum bar at about 800 deg F and the cut needs to be complete in less than 1 second and at the shortest desired lengths, the cut would occur every 3 seconds.
    I am thinking something like an Iron Worker Shearing action that would leave a nice square cut and we would mount this on a carriage that synched up with the bar as it was coming out of the caster (we are driving the casting wheel and have an accurate sense of position at all times). Based on similar systems we should be able to achieve +/- 0.030 inch cut accuracy if we comp for temps.
    Anyone have a lead on a small form factor shear that we could integrate into a reciprocating carriage like this?
    This is a flying shear for sheet metal - we are looking to emulate something similar to this with 3" bar stock.
    Dec 2014
    Arizona
    368
    39
    62
    Check out CaseyUSA.com. They have quite the selection of hot shears for bar up to 4". Maybe even bigger, but special order.
    Dec 2014
    Arizona
    368
    39
    62
    I don't know about small though.
    Oct 2005
    14,511
    I would ask if their die system can be used on solid square (I think it might)
    The Ultimate High Speed Automatic Tube Cutter | Vulcan Tools
    Dec 2003
    Washington
    4,633
    2134
    3922
    thanks for the links . . . I am space constrained. (This customer came to us because they realized that they would probably need something custom designed from scratch, we have the carriage and controls figured out - the shear is another animal)
    Mar 2009
    Eureka, CA
    3,708
    730
    1261
    I certainly would think 'sawing' before I thought 'shearing'. A stout motor and well designed carbide blade with a water spray mounted on a carriage moving with the flow of material. The 3 second time limit could be tough one to meet.
    Stuart
    Mar 2005
    Kansas
    7,410
    424
    3393
    Is standard guillotine shear configuration acceptable, or does each blade need to confine two sides to minimize distortion? For curiosity's sake, what is the shear strength of 800F aluminum straight from the concaster?
  8. Likes motion guru liked this post
  9. #8
    Dec 2003
    Washington
    4,633
    2134
    3922
    sawing is out of the question - no water allowed in the area and chips not wanted either.
    Distortion is not that critical - these bars will be melted down again and used to alloy larger batches. A decently square cut would be nice for crating / shipping purposes.
    I reached out to these guys with a query and will see what they might have to say . . . Advanced Machine Design
  10. #9
    Apr 2002
    Syracuse, NY USA
    9,687
    18
    576
    how about a standard shear section from a iron worked in a custom built hydralic press frame. lots of flow needed to get that cycle rate, but tonnage not a problem and it should be compact.
  11. Likes motion guru, NAST555 liked this post
  12. #10
    May 2002
    South Central PA
    13,440
    2168
    3364
    I've seen Ironworkers shear up to 2" square steel bar, is there something there that can be incorporated or adapted?
  13. Likes motion guru liked this post
  14. #11
    Mar 2009
    Eureka, CA
    3,708
    730
    1261
    Quote Originally Posted by Mud View Post
    Do it in 1 second..every 3 seconds. That would be quite the mechanism.
    Stuart
  15. #12
    Dec 2003
    Washington
    4,633
    2134
    3922
    I misspoke . . . the fastest cycle time would typically be 5 seconds minimum.
  16. #13
    Jul 2006
    Hillsboro, New Hampshire
    7,160
    1674
    4922
    Quote Originally Posted by motion guru View Post
    Hi Motion,
    What's the available envelope, and do you have a tensile strength estimate for the Al alloy at 800F [mimicking gbent's question]?
  17. #14
    Dec 2003
    Washington
    4,633
    2134
    3922
    We can occupy only 6 feet of line length between caster and reducing mill. I don’t know what the shear strength is . . . Researching.
  18. #15
    Oct 2005
    14,511
    I would go with a mechanical punch press (new style with clutch/brake) for the speed needed.
    But....sliding that mass back/forth on the flying cut-off carriage is tough.
    Hydraulic ?
    Look at what the hydraulic press makers came up with for "rapid forging" in the 1960's....IIRC Pacific press made one.
    Basically a large nail gun.
    But hydraulics are used to return the ram, compressing the nitrogen filled piston.
    Actuation is by lifting the head off the top of the cylinder, so the whole top allows the inrush of the nitrogen.
    Double opposing ram designs are also used to counteract any movement of the press.
    CeCo name comes to mind.
  19. #16
    Dec 2007
    Central Ohio USA
    3,791
    70
    1701
    So, while I was killing time looking up the strength of aluminum at 800 degrees, I ran across this write-up:
    800-Degree Aluminum Spill: Forklift Driver Puts Colleagues in Mortal Danger | foundry-planet.com - B2B Portal
    If the aluminum in the story "exploded" when it hit a lesser-temp surface, could you leverage that thermal sensitivity for faster cutting -- as long as you can contain the shrapnel?
  20. Likes motion guru liked this post
  21. #17
    Jul 2011
    Navasota / Whitehall Texas
    3,570
    2615
    1977
    Quote Originally Posted by Chip Chester View Post
    I think they were talking about 800 degrees C in that article... Not 800 degrees Fahrenheit
  22. Likes Chip Chester liked this post
  23. #18
    Mar 2005
    Kansas
    7,410
    424
    3393
    800F vs 800C
  24. Likes Chip Chester liked this post
  25. #19
    Jul 2006
    7,160
    1674
    4922
    swatkins and gbent - yup, C vs. F, as noted by being molten. At 800F the aluminum will likely not yet be in a "sorta like toothpaste" state, but that can vary depending on silicon content, and perhaps other alloys. I'm going to guess shear and tensile will be pretty low, which should help with slicing, perhaps like pure lead.
    I'd be looking at a flying pivoting chopper blade, with a not-cutting counterbalance to reduce vibration, both as compact to the structure as possible to minimize overturning forces. I asked about envelope not just for length, but also for width and height, and what is in the area for linear guiding (such as profile rails, which if not present would need to be added).
  26. #20
    Dec 2007
    Central Ohio USA
    3,791
    70
    1701
    Quote Originally Posted by swatkins View Post
    Details, details... Toasty by any measure, though.
