New Chinese Press Brake
Results 1 to 11 of 11
    Oct 2019
    Alaska
    8
    Default New Chinese Press Brake
    Hey guys. I picked up this new to me Chinese made press brake. The story is, A guy bought it new. Didnt have a place to put it, didnt have three phase power, and after 7 years of storing it and never having it fully operational, sold it. I paid very, very little for it. Machinery is very rare and very expensive in alaska. I was thrilled even though it is typical Chinese craftsmanship. It looks to have good bones, seimens electrical components, valve body looks good, I dont see why it wouldn't work. Both motors are being reround for 240 three phase (they came 440 only) by a friend. While its apart, I am doing some quality improvements.
    Id like to add a hydraulic filter. It has a strainer, but id like to add a Spin on Hydraulic filter. Maybe like 3 or 10 Microns. Where would you suggest putting it? Return line? You can see where everything returns from the valve body. I would have to cut into the return line before it enters the valve body and weld on fitting to go into the filter base. What flow and pressure rating do you think I would need? Pump produces about 5000PSI. Below are some photos
    Feb 2013
    Northern califorina, usa
    214
    64
    My 2 cents worth, leave well enough alone, stay with the factory oil strainer. Most early American press brakes used only a serviceable strainer built into the hydraulic oil tank, or a canister unit. Under normal circumstances there's generally not a lot of contamination found in a good sealed hydraulic system. The strainer is there to pick up internal contamination such as ram cylinder packing breakdown and such.
  3. Likes digger doug liked this post
    Oct 2019
    Alaska
    8
    Really? I thought hydraulic systems were super sensitive and particles would break down tolerances. Perhaps I will just change the oil after the first 20 hours or so to try and get all the initial particles from fabrication. I guess most things like that should eventually get settle in the bottom of the tank and get collected by the magnet.
    Oct 2005
    15,985
    Hydraulic oil is non detergent, the tank should be big enough (3 minute rule)
    for dirt, water, and fines to settle out.
    May 2011
    New Jersey
    609
    12
    207
    As said, it should self separate, but if you really need to put a filter in, go way oversized so you have plenty of filtering. My 230 tom press brake has a screen for larger stuff but it is not for general filtering
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,059
    1497
    2465
    Please post more about the machine when you get it operational.
    Oct 2019
    Alaska
    8
    I will post more info when it’s operational. Right now I am shopping for new heaters as I had the motors rewound for 240v. What kinda hydraulic oil would you recommend. Shop temp stays around 60 degrees. Won’t be used in production so the oil probably won’t get super hot.
  9. #8
    Jan 2002
    9,059
    1497
    2465
    I'd use either AW32 (10 weight) or AW 46 (20wt).
  10. #9
    Jul 2009
    Munster, In. USA
    2,368
    487
    737
    Quote Originally Posted by dana gear View Post
    Poor housekeeping is what I have found working on China-made machines with hydraulic components. The reservoir has been the largest source of contamination ranging from metal fines to loose casting sand.
    One look at that filter shows you have to do some cleaning in that oil tank.
    John
  11. Likes sfriedberg liked this post
  12. #10
    Feb 2009
    Midwestern MN/Wi USA
    1,352
    74
    372
    Are chinese press brakes cast iron? What about the other ones...Trumpf, MVD, Bystronic. Are not most of them cut from plate? Are they really cast iron?
  13. #11
    Oct 2019
    Alaska
    8
    Nothing is cast iron on this. The main frame is around 1.25” plate steel. All stick welded together the covered in bondo. From a glance it looks like cast because of the welds hidden in bondo. Actually I’ve never seen a cast iron brake. The contaminates jhruska mentioned are real though. Stick welding slag, grinding dust and gummed up old hydraulic fluid. I since scrubed out the tank and then blew out the strainer to remove the caking on it.
    From watching YouTube videos of these leaving the factory... I think they are tested first then drained before shipping. This would explain why the tank had oil residue and the lines were full of sludge as it has been sitting for years after being imported.
