Mike C.
- Nov 25, 2004
- Birmingham, AL
What the heck, figure I'll post some pics of my latest project. I scored a load of 2x5" 1/8" wall rectangle tubing a couple of years back with the intent of doing this. I got 54 20+ ft pieces with a couple of shorts and one almost 25ft long in the pile, well over 1000 linear ft all up. I hate wooden decks with a passion, even more so now that the pressure treat wood is getting so sorry. Decided to go at it and see how much of this old school fab work I remembered.
I built the first one a year ago. It was all done in my shop, as it was only 6x16ft. It's the one with boards on it. The new one was 10x14, so too damned big to flip over in the shop. I welded the top of the perimeter on the shop floor to get it straight, then dragged it outside to finish.
I tried to set up my bandsaw for all the cuts, but it was taking forever and cutting crooked, so I drew off the lines in chalk, fired up the old Airco cutting torch with a #00 tip and started whacking away. MUCH faster and that little tip is like a scalpel. Very low oxygen use, so probably cheaper than buying bandsaw blades.
Welding on the first one in the shop and the perimeter on the new one was done with my Hobart Tigwave in stick mode. 6013 rods running DC on almost everything. Not enough leads to make it out in the yard, so I fired up the old 1974 Hobart GR303. I had forgotten how sweet an old DC engine welder runs a rod. Vertical, overhead, all a breeze with that old beast. Must have had 3 gallons of water in the fuel when I started, but it finally cleared up.
Raising to vertical the first time was with floor jack and engine hoist. Slow and NOT fun. Plumber friend loaned me a little JCB mini excavator to handle flipping and moving it for final installation, which made things a lot smoother.
Have concrete this one in place, remove the four temporary legs, then build and attach another 6x16 around the corner of the house to catch another door. Just get to work in my spare time and weekends. Hoping to be finished in a month or two.
