New forum member here, question on repair of lower a-arm taper
modot66
Dec 30, 2019
San Diego, CA
hi everyone, have a project i was looking for help/tips/guidance on. my older off road UTV (never street driven) has been eating ball joints and i think i found the culprit. on one of the rides the castle nut on the ball joint fell off which allowed the ball joint to open up the tapered hole in the a-arm (see pic).
has anyone ever had to repair anything like this?
the a-arm was custom made by a company that is no longer in business so i am trying to fix this one. i can tig, mig, and stick but do not have access to a lathe or mill. my thoughts were to tig weld and build the walls up, then taper ream it back to original dimensions. i have also seen weld-in taper sleeves but am not sure my drill press chuck could handle drilling the a-arm out to accept the sleeve.
any ideas or tips? i think the taper on the ball joint is a 7 degree taper based on my rough measurements. if anyone has tips on how to measure taper too i would be grateful.
From the looks of that A arm more like a complete new one would be in order. But as above weld in a repair taper sleeve. Fabricated piece with broken welds Sheesh !
My advice:
Find a shop to bore it out for you and use the weld-in taper sleeve.
Since those holes are wallowed out so much that's probably the best idea for fixing this. Years ago we used to do
a lot of custom automotive work and we had a number of reamers ground up for making new parts and also doing
repairs. The taper is 1-1/2"-12" included angle which works out to 7.125 degrees.
If you can build the holes up and find a reamer it's an easy fix but if you don't have access to a reamer the inserts
are a good second choice.
If you want to do it "farmer style" you can build up the hole, drill it out to the appropriate size and use the spud from
a disassembled tie-rod end to form the taper. Heat the area around the hole till it's red hot and use a big hammer
to drive the spud of the tie rod into the hole. It will create a taper that is more than adequate for most situations. :D
We usually took the spud from the tie rod end and welded it to a chunk of solid round stock to create a punch that
was easier to handle...
trust me i would love a new arm, but the company that made these has been out of business for a few years
any tips on how to measure taper? i measured the big and small end then measured the distance between the two and put into a taper calculator. i wasn't able to be accurate enough as after measuring twice i came up with a 1.3"-12" and then a 1.9"-12" taper. if i could find the right taper then building it up and reaming it out would be my first choice.
i like the idea too of farmer style!
my other option is to just weld the ball joint in then if i ever have to replace the ball joint grind it out.
I wouldn't weld on the balljoint itself as that will take the temper out of the steel, or worse yet, embrittle it. either way, you are creating a "break here" situation, and asking for a catastrophic failure. not saying it couldn't be done safely, but NO, just don't do it, its a really bad idea!
