Bought this rig and prev owner apparently was on a mission to see what he could hit. The doors and such are being replaced but I am trying to figure out a plan on the main house frame. That is formed single wall steel that is .200" thick. the main issue is there really is nothing to safely push against inside the doors for a porta power. they are also stitch welded along the bottom and no way to remove from machine.
I am trying not to over thinking this. I was thinking about a piece of Ibeam over the outside so I could try a clamping technique, but not if if we will need heat or not? The very back of the machine is a cast iron counterweight so it is safe to push on for days.
I thought about welding studs on to pull on but then I have to fix all that. We will eventually paint the machine in which I can get a little mud in these areas. Obviously it is a work machine so I need to align my head with that, but I can't stand beat up equipment. I want it to at least look better.
