vonblowseph
Cast Iron
- Mar 11, 2010
- athens ohio
The machine is a Linde Heliarc 250HF. I'm assuming it is from the early eighties like a lot of stuff in this shop.
It does not want to start an arc, on both AC or DC.
Last time I experienced this it was with a miller machine that we had at my other job it was much newer. I called miller and described the issue and they said it needed new HF board. Sent it away and it worked great once we got it back.
So, given that experience I'm assuming that this machine has a HF problem. I called ESAB and they said to check and make sure that the HF switch works before trying to get a new board.
Anyone got anything to help me trouble shoot this?
Am I wrong to assume that the arc not starting is a high frequency issue? I don't really know how welders work per say, just know how to use them. Of course, I don't consider myself an expert on that either.
I have handed the board off to an electronics expert in the building and he is gonna look at the switch and board to see if there is anything obvious he can fix.
Joey
Joey
