OT - Bending with a 400 Ton Bertram press
Results 1 to 19 of 19
    Feb 2005
    Vancouver B.C.
    859
    15
    138
    Default OT - Bending with a 400 Ton Bertram press
    So user Collector is about to scrap his 400 ton Bertram press and we ran her for the last time. I wanted to show one of the guys how quickly the tonnage gauge climbs up and we found a 2x4 piece of steel.
    It bent it at 160 tons without the pump seeming like it was being loaded... What a thing to see.
    This probably could have been a good forging press, there is two small 4" cylinders that move the ram very quickly in advance and retract and then another button on the pendant engages the main 16" cylinder for high pressure.
    It's awe inspiring how quickly the tonnage gauge goes from zero to over 100 tons. There is a ten second or so delay after pushing the high pressure button until pressure builds. Then in under two seconds the needle is over 100 tons...
    I'll try to put some video up later.bent-bar1.jpgbertram-1.jpgbertram-4.jpgbertram-5.jpgbertram-3.jpg
    Jun 2016
    New York
    1,891
    1232
    905
    Quote Originally Posted by Chris999 View Post
    Oh crap, I really want that!! Too far too heavy, but man, I REALLY want that..
    May 2011
    New Jersey
    650
    14
    221
    I'm second in line. Ship it to NJ, I'll keep it forever.
    Mar 2005
    Kansas
    7,910
    489
    3761
    Hard way, even. That is impressive. Somebody was looking for a small, high tonnage press brake. That looks like a good starter kit to me.
    Oct 2005
    17,829
    It looks like it should knock down by removing the strain bars, and unhooking the hydraulics
    from the main ram.
    Everything could go on strapped to a couple of oversized pallets (maybe 4' wide but much longer)
    Aug 2012
    California, Central Coast
    4,430
    2287
    1770
    I would buy it if time and distance were not such a constraint. Maybe his old monarch 16x54 also, not sure I saw pics of it.
    There or more pics of this press in his photo gallery, linked to in this thread:
    Final Blowout of Collector's machinery
    Oct 2012
    Albany Ny USA
    433
    1510
    209
    Forgive my ignorance, but what exactly is(or was...) a press like that used for?
    Most of the presses I've seen or been around were vertical and apart from a log splitter, horizontal squishing power seems odd to me. I am just a welder though...
    All that being said I wish I could give that thing a home. It's a shame to see something like that go to the scrap yard...
    Oct 2011
    CANADA
    British Columbia
    640
    55
    403
    Cool to see large presses. Thanks. I participated in building a 3000 ton press. It was horizontal and was for bending Large pipe. The test piece they bent was over one meter in diameter and the wall was over an inch thick. Then it was shipped to Britain with an operator to teach. It has something like 25 implement cylinders ganged to push a wall about six feet by six feet. The hydraulic power pack was on a separate skid with a 25 hp motor. I don't remember how many barrels of hydraulic fluid we used to fill the reservoir. It was meant to make seismic bends that would go out to a pipeline. The gradual S bend would allow for shifts in the ground.
    I worked in one shop where we had a horizontal rated at 80 tons to bend beams to give them a camber. We called it the bulldozer. Lots of applications besides pushing collars on and off shafts.
  9. Likes PlasmaOnTheBrain liked this post
  10. #9
    Oct 2005
    17,829
    Quote Originally Posted by PlasmaOnTheBrain View Post
    The wheels on the train go round and round....and have a large press fit, to keep them
    doing that.
    YouTube
    Also, larger motor shops have these for all manner of pully's on shafts, etc.
  11. Likes PlasmaOnTheBrain liked this post
  12. #10
    Mar 2004
    Edison Washington USA
    10,574
    1030
    5612
    These horizontal presses were used in boat engine repair shops around the NW. I was in an old shop once that had one much like this, but a hundred years older- it ran on plain old water, but functionally was almost identical. It was in a shop that spent 50 years rebuilding logging tugs and small utility boats on Puget Sound, and they pressed collars, bearings, prop shafts, props- all kinds of long shafts and the things that went on them, that would be impractical to press in a vertical position. Even a small tug could have 30 feet of shaft attached, much easier to sling it horizontal. The shops I have seen didnt do automotive or construction machinery, but this configuration would be hand for some of that stuff, too.
  13. Likes PlasmaOnTheBrain liked this post
  14. #11
    Dec 2008
    minnesota
    182
    35
    175
    Every railroad shop had one of those.
    The sales brochures called them a WHEEL PRESS.
  15. #12
    Feb 2008
    Mishawaka, IN
    358
    41
    86
    Default status of the press
    Has the fate of this press been executed?
  16. #13
    Aug 2015
    Illinois
    1,502
    1110
    649
    Sugar mills also had them for pressing huge gears off or onto shafts.
  17. #14
    Mar 2011
    Geneva Illinois USA
    6,440
    2817
    2524
    Cheaper just to buy the whole shop and move in next door.
    Tom
  18. #15
    Oct 2005
    17,829
    Quote Originally Posted by TDegenhart View Post
    Tom
    I think that press will break down pretty easily, to something shippable on a couple of oversized pallets.
    The strain bars bolt on (or simply pin) and the press head and other end simply slide along them.
    I have seen very similar presses mounted vertically, with the piston in the floor,
    working up.
  19. #16
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,157
    451
    1081
    What happened to the original shop? Wasn't this the shop with the big bridge crane and Turciting various Monarchs back to pristine alignment specs?
  20. #17
    Feb 2005
    Vancouver B.C.
    859
    15
    138
    Quote Originally Posted by matt_isserstedt View Post
    Shane sold the building. He's downsized and moved into his retirement shop. Unpacking may take a while...
  21. #18
    May 2020
    CANADA
    Ontario
    Is that press still around?
  22. #19
    Feb 2013
    Northern califorina, usa
    344
    5
    120
    Last year we replaced a 1950 era Chicago D&K 500 ton hydraulic press brake with 7' bed with 6'of day light.
    Pretty nice machine overall, it used a tape wire to control travel of stroke between the rams that needed a little TLC now and then, other then that it worked good with no significant oil leaks.
    I offered it for free to several local fab shops, without the dies. We could lift and load but they had to haul and unload on there end.
    This things very heavy, the moving cost and size scared off everyone even at free. We moved it into our bone yard, drained the hydraulic oil and it went to scrap this spring.
