OT: I am considering building a trailer- sub frame out? - Page 5
Page 5 of 5 FirstFirst ... 345
Results 81 to 83 of 83
  1. #81
    Dec 2007
    Central Ohio USA
    3,979
    95
    1788
    Here's the ticket:
    https://thevmcgroup.com/Catalog/SubC...=0&subCatId=94
    Full engineering specs in the pdf's.
    Tough, secure, stainless, add/change/delete if capacity or distribution changes. Damping. Aluminum bars available to combat dissimilar metal corrosion. It's the bees' knees.
    Last edited by Chip Chester; 02-04-2020 at 10:52 AM. Reason: Shameful plural posessive error.
  2. Likes Trboatworks liked this post
  3. #82
    Oct 2010
    Maryland- USA
    4,267
    2172
    2646
    Quote Originally Posted by Chip Chester View Post
    Here's the ticket:
    Tough, secure, stainless, add/change/delete if capacity or distribution changes. Damping. Aluminum bars available to combat dissimilar metal corrosion. It's the bees knees.
    THAT I like.
    (And ponder the miles of stainless wire rope always present in the scrap bin)...
    Edit- that product is carried by McMaster:
    McMaster-Carr
    Somehow I had missed it..
  4. #83
    Sep 2002
    People's Republic
    4,603
    450
    2778
    So I was thinking that in an I beam the vertical provides the strength and the flange keeps it from twisting, so maybe a box is similar
    Then I was thinking but the weld on a vertical would be so narrow you would be way over loaded before that was an issue
    Then I was thinking the fully welded tube would increase the strength enough by adding the cross piece it would not matter
    Then I decided I had no idea
