OT? Lift Start TIG for small inverter welder, thoughts? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Nov 2013
    Eastern Massachusetts, USA
    4,098
    4411
    4297
    Update:
    Well I got everything put together and tried it out.
    The lift start is very easy to use and I love the control the TIG gives me. All I have had time to do so far is a few tack welds on sheet metal and I am very pleased. The more serious uses will have to wait till I have more time to play with it and figure how things go with different current settings, gas nozzle sizes, etc.
    Ries, I took your suggestion about pointing both ends of the tungsten - a great idea.
    This is going to be a very useful tool for the money spent. Thanks to all for your help and suggestions.
  2. #22
    Aug 2012
    California, Central Coast
    3,331
    2153
    1296
    What did you end up doing for your gas flow? Does the machine have a built in gas solenoid?
  3. #23
    Nov 2013
    4,098
    4411
    4297
    Quote Originally Posted by Rob F. View Post
    At this time there is no solenoid. The torch connects directly to the regulator and there is a valve on the handle. Per the manual I set gas flow to 20 cu ft/hr and I roll the gas on with my thumb just prior to welding and let it run for a few seconds after.
    I did this just to try it. Those are 2 tiny finish nails welded at the tips. I held the heat on a little too long which is why it melted down so far. As I said, I need more practice.
    They are only held in the pliers for the photo. I had clamped them in a small drill press vise with a contact bar for the ground.
