The plot thickens- three roll bender build.
Results 1 to 15 of 15
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    Default The plot thickens- three roll bender build.
    I’m tickled- just got the plate in from the plasma shop.
    Some welding and bolt up work to go and this will be good to go.
    Lucky find that old grinder base to bolt this to.
  2. Likes Ries, adh2000 liked this post
  3. #2
    Oct 2019
    NICARAGUA
    106
    41
    Looking good!
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    Some photos of this coming along- still a bit more work to go before welding up...
  5. Likes Ray Behner liked this post
  6. #4
    Sep 2010
    Oklahoma City, OK
    4,842
    856
    2011
    What dies are you going to use?
  7. #5
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    I am turning the dies for the extrusions I have to roll.
    I made up bearing cores/carriers for the idlers and just press on a shell for each die while the drive wheel is a keyed slip fit.
    These are the idler cores from some 4140:
    This is the idler set with flats for shell:
    The first set are just flats.
    These are 4” turned from some mystery plastic rod I had in shop- I think nylon.
    The idler axles are 1-1/8” 4140 and the drive axle is 1-5/8” scrap keel bolt.
    The drive axle not yet keyed for wheel or die.
    The drive dies will slip over axle and also have 4” OD.
    I think the rig will have enough balls for the work I need it for.
    If it all works out I might power the unit and left room on the drive shaft for a pulley.
    It will take a few minutes to change out but this is an occasional use rig so that’s fine by me..
    I am kinda winging this and really have no ideal if it will work..
    This is the first extrusion I have to roll to a 12’ radius:
    That one is 3” x 1-1/4”
    Next up is 1-3/4” x 3/4” of the same shape but with two internal stiffeners.
    I intend to try both on flat die wheels.
    If this bender does the trick it will be a hoot- job well done.
    If not I will be wondering what the hell I have been doing for the last couple of days...
  8. Likes Cole2534 liked this post
  9. #6
    Sep 2010
    Vancouver Canada
    965
    728
    355
    Where did you get that hand wheel? It looks like a wheel off a race yacht.
  10. #7
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    It is- a 45’ wooden racer was cut up and this was her wheel.
    It seems the perfect size, is stout and already wrapped for grip.
  11. Likes rcoope, Ray Behner, dalmatiangirl61 liked this post
  12. #8
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    As it turns out the first stock I need to roll is a 2” x 1/8” architectural angle in 6063-T52.
    I need half hoops rolled the easy way to 1’-4” radius.
    Does it sound possible to roll that stock that tight?
  13. #9
    Aug 2012
    California, Central Coast
    4,261
    2256
    1682
    Quote Originally Posted by Trboatworks View Post
    What do you mean by 2" x 1/8" angle? usually angle uses 3 numbers, leg, leg and thickness, like this: 2x2x1/8 or 2x1x1/8. You mention the easy way so one leg is shorter than the other...
  14. #10
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    Thanks- yes just equal leg: 2x2x1/8
    I was saying easy way for the leg in plane of bend on outside of loop.
    Given that I have never rolled any angle that is just my guess as to which way yields better..
    Edit- looked it up- this is called “leg out”.
  15. #11
    May 2011
    New Jersey
    643
    14
    217
    If you have never rolled angle, you can be in for a big surprise. I have never rolled alum angle and without a good setup for angle, it can be real rough
  16. Likes Trboatworks liked this post
  17. #12
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    Thanks- let’s see how this rolls...
    I should have this finished tomorrow and put to work next week.
    If I post bragging about some 1/4” flat rolled in a hoop the easy way you will know there is a problem...
  18. Likes memphisjed liked this post
  19. #13
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    Everything takes longer than I think.
    Tacked for welding up:
  20. #14
    Sep 2010
    Oklahoma City, OK
    4,842
    856
    2011
    Story. Of. My. Life.
    Looks great!
  21. #15
    Oct 2010
    Maryland- USA
    4,198
    2162
    2602
    Ok - it’s a wrap and it works:
    It rolls (no angle yet as I haven’t had a chance to make the dies) but, the oval rolls to the radius I need and an obligatory hoop...:
    This whole thread sorta has a HSM feel to it already so I have nothing to lose..::
    I had thrown out the shaper which I never used so had to do the lathe trick to cut the inside keyway for the drive wheel which I had never done- it works
    One oversight- In the fullness of time I am going to replace the top axle and carry it further out the back side to have a set of open dies.
    I had wanted full support for the primary rollers so I could really lay into them for heavy work but seeing this now a open set would be a snap for small stock in closed loops etc.
    Shoot- now that I supposedly know how to weld I can weld on a stub axle and save me the work of turning the whole thing again.
  22. Likes memphisjed liked this post
