Preheating cast iron question
Results 1 to 2 of 2
    Mar 2002
    dallas,tx
    2,567
    609
    488
    Default Preheating cast iron question
    I have a small cast iron cylinder head 6-8" dia. that has some casting flaws that I was going to flow some braze or silver solder on to it. It will be fully cleaned (blasted). Would it be wise to throw it on the Barbee for a bit ,get good and hot and then use the torch to finish the job, then leave it on the grill to gradually cool down? Or is this a bunch of overkill?
  2. Likes PlasmaOnTheBrain liked this post
  3. #2
    Apr 2015
    AUSTRALIA
    775
    39
    170
    I would not worry about it, fill with a bit of filler its easier that's if its a water-cooled head.
    The heating can warp the head...if you do it cooling slow can be done by placing in a steel bucket of builders lime and covering it with at least 4 inches of cover and a lid on the bucket it should take a day or so to cool.
  4. Likes PlasmaOnTheBrain liked this post
