I have a WWII era Verson 54" mystery tonnage mechanical press brake. I'm changing the 480v only ram adjustment motor/gearbox out for a Bridgeport powerfeed unit and I had to pull the ram. While I'm getting all the pieces cleaned up figured I'd ask what acceptable clearances should be in the ram guides? Should they be adjusted straight or set to be tighter at the bottom?
Thanks!
Thanks!
