Press brake ram way clearance?
Results 1 to 4 of 4
    Oct 2009
    Oregon
    4,968
    5386
    2548
    Default Press brake ram way clearance?
    I have a WWII era Verson 54" mystery tonnage mechanical press brake. I'm changing the 480v only ram adjustment motor/gearbox out for a Bridgeport powerfeed unit and I had to pull the ram. While I'm getting all the pieces cleaned up figured I'd ask what acceptable clearances should be in the ram guides? Should they be adjusted straight or set to be tighter at the bottom?
    Thanks!
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,204
    1585
    2564
    Nobody knows so I'll take a guess with common sense.
    Leave enough space for lube oil or grease whichever it uses.
    So .005? If that doesn't work and the slop effects the machines performance, go to .002?
    I'll also guess straight not tighter at the bottom.
  3. Likes Garwood liked this post
    Oct 2009
    Oregon
    4,968
    5386
    2548
    Thanks, that makes sense.
    I figured I'd put it together with oil and snug things up with a feeler gauge in there. Cycle it a few times then grease well.
    If anyone else is running an old press brake it might really behoove you to pull the adjusters and guides apart if you haven't done it in awhile. The press I have was a war machine before running a production part for Freightliner for 50+ years. It saw very light use for the past decade. Amazingly, everything is in pretty good shape, but the grease that was in it was hard as a rock. I think running it non-stop would have destroyed it in short order had I not cleaned it out.
    It's going into production Monday so we will see...
    Feb 2013
    Northern califorina, usa
    382
    7
    132
    As a rule of thumb on our press brakes we adjust for .003 all the way.
    We have done this on our Versons, Chicago and Cincinnati press brakes up to 500 ton capacity.
  6. Likes Garwood liked this post
