lacalero
- Nov 2, 2008
- Bellevue MI 49021
Hello
I have a Promecam RG 104 100 ton about 13ft in length manufacture date 1974.The problem I have is that the right side of the lower beam sat about .375 lower than the left side I was able to jack up the right side and rotate the lower right side cam clockwise about 25 deg. now the beam sits .188 lower better but still a problem.I have bought 2 different manuals but neither one gets into any detail about adjustments I also called Amada about this issue but did not get any help. Also do the graduated drums on either end of the lower beam have any thing to do with this adjustment. Any help with this issue will be greatly appreciated.
Thank You
Thank You
