A good buy for a fab shop that just needed to touch up cutting edges for flat top punch or die. If that's a fine adjust dial on the back side it's faster (if a bit more crude) than using a surface grinder for sharpening. At .25/lb I'd say you got a real good buy if motor is ok. Some provision for dressing the wheel is needed, didn't notice one. Leaves a better, longer lasting cutting edge than facing with carbide or using the belt sander(!). Only drawback, as with any grinder, is the temptation to grind off too much at once and ruin the hardness of the workpiece by overheating. It's not just a conversation piece it's a good addition for a fab shop with a turret puncher that doesn't want to purchase a surface grinder due to cost or lack of available room.
