question about large punch presses
Results 1 to 13 of 13
    Sep 2002
    Valley City, ND USA
    1,034
    32
    39
    Default question about large punch presses
    I spent the last few days(off and on) cutting out a 2.5" wide by 6" long slot in a piece of 2.375" thick A36 plate. Made me wonder if there exists a press big enough to punch out a slug that size? Never seen or heard of such things but have not seen everything that's out there.
    Dale
    Nov 2017
    27
    6
    The sides of the slot would not be anywhere near straight. Using the 10% clearance rule, you'd need almost a quarter inch of clearance between the punch & die. If that's not a problem, then you'll need lots of tonnage & one hellacious punch and die set. How many you got to do?
    May 2003
    Iowa
    10,276
    3395
    4066
    Yes, there are some very large presses out there. Plus what Pyro said, your slot would look like crap.
    JR
    Sep 2002
    Valley City, ND USA
    1,034
    32
    39
    Thanks for the responses Anybody have a way to calculate what kind of tonnage it would take to punch this out? I know it would not be practical, but is it feasible?
    Jul 2011
    119
    108
    46
    I do not think it is practical or feasible. You would need at least a 1000 ton press and some major hearing protection. I once punched a 1.25 diameter hole in 1 inch thick hot rolled steel using a 400 ton press. It did pierce the hole but the punch broke after piercing. The slug hammered out the bottom of the press and shot across the floor. When I did find the slug about 5 minutes later it was still smoking hot. The slug measured about .100" shorter in length and was a lovely hourglass shape, kinda like an air gun pellet. The noise it made was like a shotgun blast. Never tried it again and hopefully I will never have to. The boss saved the slug and used it as a desk ornament.
    May 2003
    Iowa
    10,276
    3395
    4066
    I came up with an EWAG of 3800+ tons, but that was early this morning. guessed that the ends were radiused.
    IIRC I used a 20" perimeter.
    Perimeter of slot * thickness * 80 tons.
    JR
  7. Likes digger doug, TDegenhart liked this post
    Oct 2005
    10,340
    17390
    5399
    Quote Originally Posted by gwbolton View Post
    Don't know what you did wrong, however what you describe has been done for
    a very long time, and even in multiples, all in one stroke.
  9. #8
    Oct 2005
    10,340
    17390
    5399
    What's that you say ?
    You can't forge rear axle spindles cold.....that
    would be crazy....
    https://www.sae.org/publications/tec...ontent/620134/
  10. #9
    Jan 2014
    Houston, USA
    342
    1029
    231
  11. #10
    Mar 2005
    Kansas
    6,742
    360
    2922
    Quote Originally Posted by JRIowa View Post
    JR
    Isn't that formula Dia*thickness*80? When you use perimeter directly you need shear strength, which would be 25 tons/in2. That trims it to only 1200 tons. That die set will be so cheap you better order a spare.
  12. #11
    Oct 2005
    10,340
    17390
    5399
    Quote Originally Posted by rbdjr59 View Post
    No fair, you got the electrons all excited in the part, makes them loosey goosey.
  13. Likes rbdjr59 liked this post
  14. #12
    Dec 2004
    uk
    12,617
    3563
    5681
    Probaly make a lot more sense to just burn them in or water jet - plasma. both will do that very very easily with no excitment or so much value in a press it makes no sense.
  15. #13
    May 2003
    Iowa
    10,276
    3395
    4066
    Quote Originally Posted by gbent View Post
    That's why I said EWAG. I knew is was something times something else.
    JR
