Question on Esab 253
Results 1 to 8 of 8
    Jul 2017
    CANADA
    Alberta
    92
    35
    7
    Default Question on Esab 253
    d4196645-3680-4287-b739-3bf288c4254c.jpgd4196645-3680-4287-b739-3bf288c4254c.jpgI have been trying to get a manual online from Esab’ site. They offer nothing on the 253 I need to know what the control knob reading from O-10 with several dots beside. I suspect it a pulse feature but I don’t know how to use it. Also I wanted to put a smaller reel of wire on it but could not remove the large spindle. Can anyone shed some light on the 253. Is it Esab’s entry level machine? You guys are awesome with such a large knowledge base.
    Oct 2011
    West-Central Illinois, USA
    1,315
    2102
    602
    Post a picture of the whole front panel with all the controls.
    It looks like the lower knob is wire speed and the upper could be pulse, spot or stitch weld timing. Need more visual for more info...
    Good luck,
    Matt
    Jul 2017
    CANADA
    Alberta
    92
    35
    7
    Maybe that control is for spray weld? Does anyone have a 253 out there?
    Oct 2005
    18,880
    "Turn the knob 1/2 way".
    See what it does.
    Jul 2017
    CANADA
    Alberta
    92
    35
    7
    Picture of panel
    Oct 2005
    18,880
    Online manual shows it as a spot weld timer.....
  7. Likes Don Gitzel liked this post
    Jul 2017
    CANADA
    Alberta
    92
    35
    7
    1f2b204d-ff6d-4f96-862c-fed1925054d4.jpg1f2b204d-ff6d-4f96-862c-fed1925054d4.jpgRepaired frame with .035 steel wire set as per chart heat high on 12 and wire speed 7. Seems like is hot however high buildup. Will keep practicing.
  9. #8
    May 2011
    New Jersey
    2,588
    236
    1402
    Grind it all off and try again, that's a mess, with a side of porosity.
  10. Likes Don Gitzel liked this post
