question re: linde VI 206 mig
Likes Likes:  0
Results 1 to 12 of 12
    Oct 2005
    tacoma washington
    1,338
    33
    Post
    i recently picked up a union carbide, linde
    mig welder, it is a base power supply and a moveable feeder assy that sets on top.
    i have had a linde 225 all in one unit for years and have a question on the new to me but old linde vi 206
    it has a rotary crank on the front that changes the voltage, i follow what that is for, but,,
    it also has a dial reostat that controls inductance, or at least that is what is labeled above the knob, it is number min 1-9 max.
    what is the inductance function?
    also is there anyone here that has one, that could clue me in on its operation?
    bob g
    Aug 2005
    Central Texas
    559
    8
    Post
    I had a Linde engine driven MIG that had inductance settings on a dial. As I recall, they were "heat" settings, somewhat like the taps on a lot of older machines. This was a big 300 amp unit for welding pipe that used .045 wire in small 5 lb rolls.
    Jan 2003
    Central Kali.
    1,981
    12
    Post
    Bob, here is a read on inductance:
    http://www.esabna.com/EUWeb/MIG_handbook/592mig3_6.htm
    HWooldridge, the 5 pound spools does not compute. My 200 amp Hobart uses 33 pound spools. [img]smile.gif[/img]
    Mar 2003
    Roswell, New Mexico
    31
    Post
    MobileBob, I have the same machine; very good welder, but more suited to production type welding (i.e. set it and forget it.) For this reason, I don't use it much, I use my Miller 250 most of the time. If you need parts or service, let me know and I'll hook you up with my friend here in Roswell; He spent a month looking for the schematic and finding the parts, but now has the source identified.
    Jimbo
    Aug 2005
    Central Texas
    559
    8
    Post
    Mike,
    This rig dated from the 1970's and was not constructed like a typical shop MIG with large rolls. It had a portable box that you carried to the weld area. The feed cables from the power unit were attached to the back of the box with only about 6 feet of cable on the gun side. The gun was a 400 amp model, very heavy duty and had the option of running water for cooling (we did not use that). In practice, you hauled the box over to the work and got it as close as possible since you only had 6 feet of gun cable. The wire feeder was rated to drive large wire, over .045, but that was the biggest size we used in it.
    Jan 2003
    Central Kali.
    1,981
    12
    Post
    HWooldridge, I understand now. I have an old Airco feeder that uses a water cooled pull gun. The drive wheels in the gun are driven by a speedometer like cable from the motor back at the feeder. Here is a pic of the gun:
    http://smg.photobucket.com/albums/v1...Aircomatic.jpg
    Oct 2005
    tacoma washington
    1,338
    33
    Post
    thanks guys for the info, looking forward to getting the old girl workin again, need to replace some contacts in the power relay.
    thanks again
    bob g
    Feb 2020
    Minnesota
    Default hey i need a manual also for this vi206 and a .23 and .30 knurled wheel
    Quote Originally Posted by Jimbo View Post
    Jimbo
    hey i need a manual also and a knurled feed wheel for .23 and .30 FOR THE VI 206 LINDE if anyone can help let me know
    Feb 2020
    Minnesota
    please post the source for parts for these old linde`s
    Feb 2020
    Minnesota
    talk about the settings what would u set it at for sheet metal thin stuff auto body stuff
  11. #11
    Dec 2019
    Wisconsin
    20
    Quote Originally Posted by SLEDHEAD34 View Post
    Millermatic(R) 141 MIG Welder | MillerWelds This is what you need for sheetmetal work.
  12. #12
    Dec 2019
    Wisconsin
    20
    https://www.northerntool.com/shop/to...1413_200471413 Here is another on that looks good.
