Questions about small pneumatic hammer
Likes Likes:  0
Results 1 to 6 of 6
    Jun 2005
    Massachusetts
    220
    43
    Default Questions about small pneumatic hammer
    Good morning,
    I recently picked up a small pneumatic hammer to use in my forging process. I saw a video here a while back about a guy in Europe who uses one of these to do ornamental forging and surface texturing.
    I am attaching 2 photos. The hammer is an Ingersoll Rand K1. It is quite old and I can't find much info about its use on-line.
    My question: How do you open this up to install the bits? Is there a trick to it? It would seem to unscrew, but won't budge. I don't want to damage it. Thanks, Tom from Mass.
    Attached Thumbnails Attached Thumbnails chipping-hammer-2.jpg   chipping-hammer.jpg
    Oct 2010
    Maryland- USA
    3,011
    1770
    1991
    Looks pretty safe to secure flat to right in vise and wrench on flats on left..
    Jun 2005
    Massachusetts
    220
    43
    Hi Trboatworks, Thanks for your response. I did try to unscrew it that way. No luck so far. The bench holding the vise did move. There is a sheet metal collar that can rotate revealing a few holes. Probably the vent holes for the air exhaust. I just wonder if you poke a pin in one of the holes to release a spring and allow the big nut to turn? Don't know. I am hoping someone who has actually used one of these will reply. Tom
    Oct 2005
    13,786
    I have one of those, and IIRC you just held the rivet set in by hand.
    Maybe Joe Micheals can comment.
    Jun 2005
    Massachusetts
    220
    43
    Thanks for the information everyone! I plan to get a few of the chisels from McMaster Carr and give this a try. Tom
    Apr 2005
    Brandon, MS
    803
    113
    156
    Agree. We used to use a ton of these things driving press fit parts in & out.
    You made sure there was a spot 4-5" long on the tool to put your hand. IIRC, the "stem" that went into the driver was just a shaft (7/8" dia maybe?") a couple inches long with a generous radius at the bottom. Can't remember if the hammer hit the end of the tool or the radius shoulder.
    Most of ours hung off of tool balancers. They would sure get heavy if I had to wrangle it very long.
