Removing parts from Laser nest
Likes Likes:  0
Results 1 to 11 of 11
    Feb 2007
    WI
    Post
    Currently, we have several people spending all day removing nested parts, deslagging them and sorting from our laser cutters. Does anyone have a resource for an automating solution that removes/sorts/cleans lasered parts?
    Thanks!
    Kelly
    Feb 2007
    Angleton, Texas
    1,714
    939
    536
    Post
    It's called a waterjet. No heat, no slag.
    Just a suggestion, see other posts here for their good and bad points.
    Dec 2004
    uk
    14,053
    4552
    6705
    Post
    how big a part? how heavy? matirial? magnetic? how delicate are they??
    Feb 2006
    New Jersey
    1,420
    7
    48
    Post
    Waterjet can't touch a laser for speed in thin materials, nor can it come close in consumable cost. Jets are pricy to run.
    What kind of laser machine?
    Feb 2007
    Angleton, Texas
    1,714
    939
    536
    Post
    As I said, just a suggestion.
    If he's looking to automate removal, sorting, and cleaning he better be ready to spend big bucks.
    Alternately, use temps for this menial work.
    May 2002
    Oregon
    692
    95
    Post
    Don't know if this explanation will make sense, but how about cutting one sheet of steel with the shapes a bit oversize, and use that as the base ejector plate, then make up another plate or 3/4" sheet of plywood with spikes placed over where each piece of metal needs to be ejected, and rig up the whole thing like a light duty press. Slide your laser-cut sheet of steel with parts into the "press" and have it push all the parts out into a container below. With a couple of air cylinders, should be as easy as stepping on an air pedal.
    Feb 2007
    Angleton, Texas
    1,714
    939
    536
    Post
    While this is a worthy suggestion, even if it works it will only solve one of his three stated problems.
    Many times small parts are deliberately left attached to the sheet with a "tag" to prevent them from falling into the table in plasma/laser/waterjet operations. This requires them to be "broken" out of the sheet. Your method may, MAY, only bend the tab.
    It's probable too that the parts can be removed from the sheet by hand faster than this arrangement.
    This still leaves them needing to be sorted, as evidently they are not all the same part, deslagged and cleaned.
    This will be a very hard operation to automate unless very large quantities justify the expenditure, more-so if the nested parts/quantities vary from sheet to sheet.
    If the quantities were high enough to justify this I would expect them to be stamping them from coil-stock already, not laser cutting them.
    Jan 2007
    wales.uk
    1,157
    124
    176
    Post
    concrete casters vibrating table, only an idea
    regards mark
    Dec 2004
    uk
    14,053
    4552
    6705
    Post
    if magnetic and u can fully cut them free, a simple magnetic pick - place robot would do the job of sorting them into types. deslagging if u cant tumble on mass will be a pita! but thats were the water jet idea starts to appeall, its all down to the job and quantities as to the correct answer though.
    Apr 2019
    New York
    6
    Default Removing parts from Laser nest
    alternative solution for Amada manufacturing equipment parts and services. We provide high-quality parts tooled to the original OEM specifications.Low cost does not mean low quality. Our parts offer the same high performance and reliability as Amada America- OEM parts. We know Amada products inside and out, and we appreciate their quality just as you do. It's what got us into this business.
    Trumpf laser parts
  11. #11
    Oct 2005
    16,559
    Quote Originally Posted by AltPartsInc View Post
    eat shit and die
    The op's question was:
    1. asked 12 years ago
    2. specially asked about removing the nest.
    Not a general inquiry for spam.
    I wonder if your company's owner understands how badly your simple post
    is damaging their reputation ?
