Repair of bronze pump impeller
Results 1 to 16 of 16
    Aug 2007
    GA
    582
    96
    Default Repair of bronze pump impeller
    I need to repair a bronze pump impeller where the pump was run so long that the spring from the seal wore a grove in the seal side deep enough to make a few small holes all the way thru. This will involve building up some material to fill the groove without it draining thru the holes. The part will get bead blasted before repair. Although I probably could use JB weld (this is just a flood coolant pump) I would prefer to use metal, can I use silver solder (HVAC type) or is there a better alternative? I'm thinking the solder will just flow thru the holes& be hard to build. I may have some silicon bronze .035 mig wire I could tig over the holes first if that would plug them so I could fill the groove with silver solder.. Any recommendations or should I just JB weld it?
    Attached Thumbnails Attached Thumbnails img_20180218_111034.jpg   img_20180218_111028.jpg
    Dec 2004
    uk
    12,594
    3538
    5668
    Its pretty easy to do that kinda stuff with TIG If going the silver solder root may pay to just make up a ring of bronze wire or similar, hell even plain old stripped copper wire to fill in the hole and provide a kinda scafold to then flood with silver solder.
    Oct 2005
    dexter mich
    215
    7
    47
    Or machine it to parallel sides and flat bottom , then machine filler piece and loctite in place it is captured and spring force will hold it in
    Aug 2007
    GA
    582
    96
    I like the wire filler idea, I don't want to machine any more material away as there is not much left there...
  5. Likes ernieflash liked this post
    Sep 2017
    Wisconsin
    174
    64
    Silicon Bronze welds really nicely but you may want to try cleaning the area with AC first.
  7. Likes ernieflash liked this post
  8. #6
    Jul 2007
    Hampton, Virginia
    2,466
    188
    180
    If you are leaning toward TIG welding you will need to make sure the base material is a lead free bronze. A year or so ago we took in a job welding some adapters in shipboard heat exchanger heads. We could never get the porosity out of the weld. The welds looked good from the outside but were actually full of holes. We also attempted to gas silver solder.
    The port engineer had told us the heads were lead free but after tracking down and calling the foundry we found they were C922 bronze. We had to switch to mechanical connections.
    Many years ago we used to make some pretty good money repairing worn and pitted impellers with TIG and, maybe by luck never had this type of problem.
    Just be aware it can happen.
    Walter
  9. Likes ernieflash liked this post
  10. #7
    Aug 2007
    GA
    582
    96
    good info, but I think I'm going to stuff a piece of 12ga wire in there and silver solder it. It wouldn't matter though if it was porous as it is wetted on both sides
  11. #8
    Aug 2007
    GA
    582
    96
    OK, just cleaned this thing, before I solder it up there is not chance those holes are supposed to be there RIGHT? img_20180226_132742.jpgimg_20180226_132732.jpg
  12. #9
    Aug 2011
    new plymouth id
    264
    22
    70
    that doesn't seem to have much wear for that size of holes that looks factory probably where the water enters the impeller usually when you see holes in a impeller there is no metal left
    edit that does look worn through on your dirty photos can you get an idea of what a new impeller of that stile of pump looks like?
  13. #10
    Aug 2007
    GA
    582
    96
    It was very worn, as it is I'm going to need to bore the cast iron pump housing for a sleeve for the seal. Everything on both sides of the seal spring wore clean through and ruined both the pictured impeller and pump housing. Unfortunately I can't find a photo of what the impeller is supposed to look like. It would probably be easier to just put a cover on the bottom of the tank and get a submersible pump, but I'd like to keep it stock...
  14. #11
    Dec 2004
    uk
    12,594
    3538
    5668
    Slots there would pull a vacuum on the seal assembly and help it both seal and not leak, unless a jet pump type arrangement i doubt it would effect output all that much if at all, thats hardly a nice impeller to start with. Post up some pictures of the seal, but at this point i would say its 50 - 50 as to OEM or wear, thats very square bottomed, some rotory pump seals i have encounted though did have the springs rest in cut outs like that on the impellor, the fixed seal then riding on the pump motor face.
  15. #12
    Oct 2005
    10,223
    17284
    5305
    Have you attempted to just BUY a replacement impeller ?
    It looks like several I have seen over the years, from standard jet (water well) pumps,
    as well as a sump pump or two.
  16. #13
    Mar 2012
    Geilenkirchen, Germany
    1,932
    1160
    955
    These pumps are dirt cheap new. I can't see fixing the thing at all. It will end up costing you at least twice as much to fix it.
  17. #14
    Aug 2015
    Illinois
    856
    706
    366
    Quote Originally Posted by steve-l View Post
    Steve is probably right.
    If you are determined to fix it I would suggest mounting the impeller on a mandrel. True up the ID, OD, and bottom of the groove. Machine a ring from a similar bronze alloy. Silver solder it in place. Put the impeller back on the mandrel and face the back of it.
  18. #15
    Aug 2007
    GA
    582
    96
    The parts for this pump are silly expensive. I silver soldered the impeller wear groove with a ring of solid copper wire, completely bored out the housing where the stationary seat was wallowed out, tapped it for a 1" npt brass plug, screwed the plug in and machined it flat then bored for a new seat from a similarly sized generic pump seal from mcmaster carr. $23 fix & 2 hoursimg_20180306_150012.jpgimg_20180306_151321.jpgimg_20180216_172455.jpgimg_20180309_150108.jpgimg_20180309_165822.jpg
  19. #16
    Aug 2007
    GA
    582
    96
