dirty old man
Stainless
- Apr 5, 2005
- Griffin, GA
I'm in the midst of repair/rebuild of a Sheldon 13" lathe and the dual sheave pulley on the upper countershaft has a chunk broken out about the size of half of a 50 cent piece. Probably will pull OK, but might induce vibration thru the belts to the spindle. So I want to remove the pulley, weld it up and remachine the sheave affected.
I'm a "fair to middling" weldor at best on cast iron. Trying to decide on the best method and filler rod to use. I have AO,stick, mig, and tig available in my shop.
I have brazing rods and flux, ni-rods, and silicon bronze tig rods. I have some ni rods that are left over from an old project of cast iron welding that have seen better days as far as the flux coating goes. Been thinking of cleaning the flux off these rods, cleanig the cast iron surface with a carbide burr, and using the tig to more closely control the filler rod flow.
Anybody ever tried a tig on cast iron?
