Rotating weld ground on a production fixture
Results 1 to 18 of 18
    Oct 2010
    Portland, OR
    739
    147
    249
    Default Rotating weld ground on a production fixture
    I'm designing a manual weld fixture where the welder will rotate a "bolt head welded to the side of a nut". It will be pre-tacked and then clamped into a rotating fixture. The current design is to use about a 1" shaft that is mounted to the rotating fixture (co-linear of course to make the rotation without wobble) and it will travel through a bushing/mount with a handle on the opposite side. Just to help out, they'll likely have a saddle for the torch to more easily keep it in position.
    I'm not an expert on weld grounding and wondering if I can pass the ground though the rotating shaft, maybe if the shaft is steel and I press a brass bushing into the support? I would like to avoid a special rotating ground that would get in the way of the operator being able to rotate the assembly while welding. Ultimately, if volume increases, we may add a motor drive/belt to rotate it via foot pedal but it will be starting out with manual rotation.
    If you look at the photo, ignore the little piece off to the right.
    Any help is appreciated.
    The Dude
    Oct 2005
    15,079
    Roto-Ground Clamps
    Tweco (and IIRC Bernard) makes others without the "c" clamp
  3. Likes The Dude, DrHook liked this post
    Nov 2013
    Eastern Massachusetts, USA
    4,210
    4489
    4370
    How many amps? Most movable connections use high current brushes (think of a subway train) so it's mainly a matter of knowing what size to get and then coupling it to your fixture. I would suggest a ring (short piece of tube) as close as possible to where the bolt mounts. For manual rotation you might even get away with using heavy copper braid and conductive grease.
    Edit: I was typing my post and didn't see the one above until after I hit "post". That sounds like the way to go.
    Oct 2010
    Portland, OR
    739
    147
    249
    Awesome, thanks guys. I was looking for somethign like that and only found something complicated but that looks far simpler and likely cheaper.
    Much appreciated!
    The Dude
    Oct 2005
    15,079
    I have seen on the small welding turntables, a brush (like for a motor, not paint) that is made from porous copper (like an compressed air filter)
    and this is spring loaded to bear upon a smooth machined face
    Jun 2016
    New York
    1,517
    840
    656
    just a note on the design, I think the pivot is too far from the weld for a single bearing, two would be better, think about using an old arbor, dividing head, or even a motor, its already got the bearings.
    as to the ground, if you have some woven copper webbing, like the lead on a brush for a largish dc motor or generator, you can really just pinch it with a spring clamp around the shaft, thats plenty for 150A or so
  8. Likes DrHook, Scottl liked this post
  9. #7
    Aug 2012
    California, Central Coast
    3,543
    2187
    1370
    I use a pair of large carbon brushes, biggest I could get at motor shop years ago, to ground a manual rotator I made years ago. 200 amp alum tig, rotates while welding. Brushes are something like 3/8" x 1 1/2" or so, spring loaded to push on rotating shaft.
    Also have a Jancy Rotostar rotator that just uses a 5/8 or so round copper plug that is spring loaded to push on the back of the table platen.
    Both work just fine.
  10. #8
    Oct 2005
    15,079
    Don't the carbon brushes act like a resistor ?
  11. #9
    Jun 2016
    New York
    1,517
    840
    656
    yes, think of how large carbon brushes would be on a 150 or 200A motor, and they would need the corresponding contact area, so I don't think I'd use them. certainly the high speed capability they have would never be needed in this application.
  12. #10
    Aug 2012
    3,543
    2187
    1370
    When I first made the rotating fixture it was just a steel bar through a steel pipe in the table, not intending to rotate while welding. Shortly the arcing inside the pipe made the thing not usable so the large motor brushes came into play. Those worked rotating 200 amp welds on aluminum for probably 20 years of production. I have my own here in my shop that has not seen that level of use but there are NO problems with them whatsoever.
    Similar is an electric rotary union.
  13. Likes digger doug liked this post
  14. #11
    Mar 2005
    Kansas
    7,465
    429
    3425
    Strip the insulation off 2 feet of welding lead. Wrap the welding lead around the shaft two or three times and put your ground clamp on the bottom where the leads overlap. The old-time woven battery ground straps work good also.
  15. Likes e-fishin-c, The Dude liked this post
  16. #12
    Aug 2012
    3,543
    2187
    1370
    Quote Originally Posted by gbent View Post
    Best to strip that amount not at the end of cable so the end dosn't fray. I have a lead like that for grounding on stainless tube. Also very useful when the ground clamp wont open wide enough to grip the OD of tube.
  17. #13
    Oct 2011
    West-Central Illinois, USA
    1,239
    1998
    564
    Quote Originally Posted by The Dude View Post
    The Dude
    Yes you can pass the power through the rotating shaft. I’ve built a number of machines for doing roundabout welds. Pandjiris uses large bronze blocks against the back of their positioner faceplate that are electrically isolated from contacting the spindle frame (so all parts need a connection to the faceplate for ground). Gleason & most other production crankshaft & overlay machines use graphite brushes on the spindle itself and isolate the spindle from the bearings and machine frame.
    I wouldn’t ground through the spindle bearing even if it were bronze. I think you’ll find things will go better with brushes bearing on the spindle itself or contacting a steel or iron disk clamped over the shaft. Spindle bearing will wear quickly with bronze & if you pass current through ball bearings they’ll fail very-very quickly.
    Brass or carbon/graphite? Both will have some arcing & graphite goes better for not chewing up a steel or iron surface by fretting. Both will have slight voltage drop through the rotating connection when in use.
    I’ll attach some brushes, 5/8x2” and 3/4x2” T900 GE type (traction motor use). When you check resistance through a good static connection they’ll be around 2 ohms. The pigtails on both sizes can handle a lot of power in open air.
    As an aside, I’ve also built what you want to do with a rotating torch. Then you can shove what ever you want in front of it (with some tube contactor changes).
    Good luck
    Matt
  18. Likes digger doug liked this post
  19. #14
    Oct 2009
    Oregon
    4,183
    4489
    2128
    Rotostar welding positioners are made right down the road from you in Clackamas. Go talk to Rob about what you are doing. I'm sure he can fix you up.
  20. #15
    Apr 2004
    Wisconsin
    1,290
    6756
    1001
    ATI torque converter welders use one of these held stationary clamped around a rotating spindle. As long as you aren't turning it fast it should work good.TWECO 300 amp Copper Ground Clamp #92051130 For Sale | Tweco | Ground Clamp | Welding Accessories | Welding Equipment | Welding | Welders Supply Company Beloit-Big Bend-Burlington Wisconsin and Rockford, Illinois
  21. #16
    Oct 2019
    NICARAGUA
    78
    16
    Some years ago I worked in a fab shop that made air duct systems. They had a positioner made from an old lathe headstock. A flat copper brush, spring loaded, rode on the back of the chuck. Worked fine for them. While you are at it, why not make a tailstock to hold the bolt and eliminate the tacking step?
  22. Likes The Dude liked this post
  23. #17
    Oct 2010
    Portland, OR
    739
    147
    249
    We ended up using the "engine block ground" method (ground strap wrapped around the rotating shaft) and, thus far, it has worked well although it's still in try-out mode. This was about $15 for the ground and a clamp nut so I would consider it to be the easiest and cheapest of all the methods suggested.
    Quote Originally Posted by PocoLoco View Post
    Actually we are looking into that, although we will likely go with a V-block so that the finished assembly can easily "tip out" when unclamped.
    Thanks all!
    The Dude
  24. #18
    Oct 2019
    NICARAGUA
    78
    16
    Glad to be of service.
    Good luck with it.
